CFM and PR calcs - something I'm not getting
Old Jul 21, 2016 | 10:17 PM
Matyikaaa90's Avatar
Default CFM and PR calcs - something I'm not getting
So I have been reading up on compressor maps and I found this post.
Lesson 1 - determining the maximum potential output of a given turbo - and lesson 2 - determining how fast a turbo will spool on our engine - seem to be pretty straightforward.
Lesson 3 though, I'm pretty "lost" here. It uses the same formula/calculator as above.
So basically if I have a B16A2 then my CFM at 8 psi would always be the same. (1.6*8200*90*1.54)/5660=~321 CFM.
And if I use the given formula for potential HP then 321/1.427=~225 hp. No matter what turbo I use at 8 psi my potential power output is 225 hp? Surely something's fishy here.
Would anybody care to explain what I'm missing?
Old Jul 22, 2016 | 01:57 AM
extremeracer's Avatar
Default Re: CFM and PR calcs - something I'm not getting
Calculate CFM (I convert to lb/min as compressor maps are usually scaled in lb/min of kg/s) for the engine in normally aspirated state
Calculate Pressure Ratio (Ambient pressure + boost pressure/ ambient pressure) > Assuming sea level and ambient presssure of 14.7 psi that is [14.7+8/14.7 = 1.544]
Multiply the NA Airflow (CFM value) by the Pressure Ratio
So 321 CFM x 1.544 = 495 CFM
495 * 0.07 = 34 lb/min
I'm assuming your Airflow calc is correct, I didn't check your formula or maths there.
Old Jul 22, 2016 | 02:51 AM
Thanks, yours is definitely a more userfriendly formula so I'm gonna use that in the future. (I calculated the CFM with 8 psi boost already, by the way)
What I'm not getting is how this formula helps me to calculate my potential power output at the SAME boost level with DIFFERENT turbos.
88_hatch_ls
Dec 5, 2012 06:58 AM
torqueless
Dec 6, 2004 07:31 PM
Soon_2b_evil
Jul 11, 2003 05:55 PM
