Honda CR-V & Element 2WD & 4WD Element & CR-V
Rich STFT after replacing both O2 sensors
Old Jul 21, 2016 | 05:19 PM
kamwrex's Avatar
Default Rich STFT after replacing both O2 sensors
CORRECTION: STFT is running LEAN (+ fuel correction), not rich.
Title says it all. I have a 2007 Honda Element EX with 120k miles on it. I replaced both O2 sensors yesterday along with the PCV valve and MAP sensor. I did all for a) regular maintenance on the vehicle (O2 sensors were 20k overdue) and b) because I have been getting a repeating P0507 CEL (Idle Air Control System RPM Higher Than Expected) that the dealership can't seem to pinpoint. Recent other part replacements include a new throttle body, MAF sensor, and APP sensor.
After replacing the O2 sensors the vehicle is now running lean at around +15-20%. I have no idea what the problem is. Did I install them wrong, did I introduce a problem by also changing the PCV valve and MAP sensor?
Old Jul 10, 2017 | 03:34 PM
eksine's Avatar
Default Re: Rich STFT after replacing both O2 sensors
If you still have the old o2 sensors plug each one back in and see if one of your new ones was faulty. If you bought a cheap aftermarket o2 sensor its possible, heres a list of other things to check including loose air hose clamps. https://forums.anandtech.com/threads/check-engine-light-code-says-o2-sensor-is-reading-lean.133478/
Hanmin
Sep 20, 2008 07:57 AM
hondaman1212
Aug 2, 2008 06:33 PM
odishaw
Feb 16, 2008 08:34 AM
CivicDXRaceCar
May 30, 2005 05:59 AM
tinkerbell
May 17, 2002 02:04 AM
