A/C System Fubar'd After Maintenance
1998 DX Hatch, 100% stock, Automatic.
Did a ghetto install on a brand new A/C system, new compressor, condenser, condenser fan, dryer, everything. Worked (inefficiently but worked) for weeks without any issue.
It worked but wasn't cooling efficiently so I had it professionally vacuumed twice and a new dryer again and another refill and it was blowing snowballs in the Florida heat but now after 3 days, it won't blow cold, low-side pressure at 91 PSI and my compressor chatters like a b**** when compressor is turned on and engaged.
All this after I had it 'professionally' maintenanced. Did the shop screw up my system? Am I unlucky and had my compressor fail? I'm not too sure what to think of any of this.
TL;DR - compressor chatter, warm air in cabin and low-side high pressure after maintenance in a whole new A/C system in a stock 98 civic hatch.
Engine off, can you spin the compressor clutch plate (the part on the front of the pulley that drives the internal compressor) by hand? It should turn rather easily with just a slight once-around hitch. Turn counterclockwise, the way the engine drives it. Scroll compressors do not like to turn backward.
marqoid
10
Jun 28, 2013 04:41 PM
ratwellnc
10
May 14, 2008 01:22 PM
snatch
Apr 27, 2006 07:05 AM
