92 LX - Intermittent Start Problem
1992 Honda civic lx automatic. Car turns on every couple of days but when it doesn't the cel stays on and the fuel pump does not prime. Some days if I leave the key forward for a couple mins the cel goes away and the car starts up. When the cel stays on on a good day i will wait about 5 mins to hear the fuel pump primes and cel goes away and starts right up. Tried to check for cel codes but the light doesn't flash. 92 with 89,000 miles no mods all factory.
First suspect is the main relay.
Also, I suggest you read the rules sticky at the top of this sub forum. The guidelines there will help you get better and more feedback to your problem.
Title edited for the same regard.
Ditto the above^^^ it is a common problem, and an easy fix most of the time...
Main Relay Fix, Troubleshooting (Honda, Acura) and how to solder
There will be no codes for bad PGM-FI Main Relay problem. 94
Hondatechnoobi
May 1, 2015 08:02 PM
ChicknNorris
24
Dec 11, 2013 10:48 AM
beegjap
Apr 27, 2011 05:54 PM
