92 Civic CX (D16Y8 swap/P28 ECU) - Blown ECU replaced but engine still won't run
Old Jul 15, 2016 | 05:40 PM
joshuad86's Avatar
Default 92 Civic CX (D16Y8 swap/P28 ECU) - Blown ECU replaced but engine still won't run
Have 92 hatch current main relay has two wires spliced pump runs constantly.. I can remove the splice and install new relay and fuel pump doesn't pump..
Old Jul 16, 2016 | 01:36 AM
delsolintegra's Avatar
Default re: 92 Civic CX (D16Y8 swap/P28 ECU) - Blown ECU replaced but engine still won't run
Maybe bad ECU fuel pump priming circuit capacitors.
Try another ECU.
Old Jul 16, 2016 | 03:40 AM
joshuad86's Avatar
Sorry to ask the dumb question but which ecu's would be compatible..Car is a 92 hatch.. Auto to manual swap.. D16y8
Old Jul 16, 2016 | 04:11 AM
I'm assuming you have a OBD 1 ECU, probably a P 28 that may have been converted from a auto P28 to a manual P28. Look for a label on the side of the ECU.
If it's a P28 just get another one at a junkyard for a manual civic.
Old Jul 16, 2016 | 08:13 AM
fcm's Avatar
fcm
Old Fart
Kind of depends on what two wires are "spliced" ?
Wire colors and or pin locations, pix would help. 94
Old Jul 16, 2016 | 09:04 AM
joshuad86's Avatar
Will get pics and more info in a few when I get home
Wires that are spliced are green/yellow and black.. Pins 8 and 2
Old Jul 17, 2016 | 08:41 AM
Former User's Avatar
Default Re: main relay???
Main relay pins 2 and 8 are spliced:
If you measure battery voltage at ECU connector pins A25 and B1 and continuity to body ground at ECU connector pins A26 and B2, then replace your ECU.
Old Jul 17, 2016 | 03:59 PM
joshuad86's Avatar
Thanks RonJ the above method tested exactly as you said.. Pulled ecu and removed cover to perfectly see burnt spot on the board
Old Jul 17, 2016 | 04:03 PM
Definitely replace the ECU.
I'll PM you about your blown ECU. Is it a P05 or P06?
Old Jul 17, 2016 | 04:06 PM
joshuad86's Avatar
Old Jul 17, 2016 | 04:09 PM
Did somebody swap in a D16Z6 engine?
Edit: I see you have a D16Y8 swap.
Old Jul 17, 2016 | 04:11 PM
joshuad86's Avatar
Its a d16y8
Old Jul 17, 2016 | 04:12 PM
gotcha
Old Jul 17, 2016 | 04:14 PM
joshuad86's Avatar
Yes sir I sure do appreciate any and all help..
Old Jul 23, 2016 | 11:55 AM
joshuad86's Avatar
Default 92 hatch starts and dies
I traded for a 92 hatch a few weeks back.. Car started I drove it had slight low end hesitation and idled up and down.. Got car home and noticed fuel pump wasn't priming and was running constantly when I key on ignition pulled down relay to see spliced wires undone splice tried new relay pump wouldn't run at all.. Came to find out the prime circuit was burnt up in ecu.. Got another ecu key on ignition pump primes once car starts idles about 2 seconds and dies.. Ran a test light to pump and I'm keeping power at pump until it dies the it primes again.. Going to test fuel pressure later but I'm at a loss with the thing
Old Jul 23, 2016 | 12:11 PM
Post the CEL codes.
Old Jul 23, 2016 | 02:17 PM
joshuad86's Avatar
Not sure of code list but I got one long(10) then it went 1 long 9 fast(19)
Old Jul 24, 2016 | 07:49 AM
Can you post a video of the CEL blinking the codes? Has the engine been swapped or is it stock (D15B8)?
Code 19 would be thrown if you are using an auto ECU with the manual transmission. There's a way to convert the ECU. Do a Google search.
Old Jul 24, 2016 | 08:09 AM
joshuad86's Avatar
I replace iat sensor and all I get now is code 19.. D16y8 motor and manual trans..z6 Manifold.. p28 ecu
Old Jul 24, 2016 | 08:12 AM
Triple check for swapped sensor connectors (by connector wire colors). Post pics if you need help. This is the most common cause of blown ECUs following a swap, and will also make the engine run like crap.
Old Jul 24, 2016 | 08:29 AM
joshuad86's Avatar
Map
Tps
Iat sensor
Not sure what the sensor is called has vaccum line on it mounted on firewall
Iacv
Old Jul 24, 2016 | 08:30 AM
joshuad86's Avatar
Anything else I need to snap a pic of?
Old Jul 24, 2016 | 08:52 AM
MAP and TPS may be swapped.
The unidentified firewall 3-wire connector is for the MAP sensor.
The Yel/Blk and Red wire connector is for the EVAP system. Where is it connected?
The ECT sensor is not shown.
(TA = IAT, TW = ECT, throttle angle = TPS)
Old Jul 24, 2016 | 09:08 AM
joshuad86's Avatar
Map tps and the fire wall sensor are in fact mixed up
Ect is red/white green/white
Old Jul 24, 2016 | 09:12 AM
Unplug your ECU, and hope you haven't already blown the new one.
Triple check ALL sensor connectors before you reconnect the ECU connectors. See diagrams I posted.
Good luck.
(Aside: Do plan on keeping the blown ECU?)
That's fine. See diagrams.
Prentice916
Jul 31, 2017 10:02 AM
static-x
Sep 27, 2015 08:54 AM
Markalark
Sep 22, 2013 03:32 PM
scottied15
Jan 2, 2013 06:08 PM
ej6kid
21
Sep 24, 2010 08:26 PM
