RSX-S Axle Replacement issues
Old Jul 9, 2016 | 08:27 PM
dvazriel's Avatar
Default RSX-S Axle Replacement issues
I'm trying to take out my driver side axle, i got the spindle nut out already but I cant remove the lower ball joint.
I cant for the life of me pop it out, will unbolting the hub from the strut work as an alternative? I know one of those bolts is the camber bolt so i might need alignment.
Old Jul 12, 2016 | 07:16 AM
trevis427's Avatar
Default Re: RSX-S Axle Replacement issues
Yes. I did this job last week actually. Unbolt the hub from the strut and you'll just have to use a little muscle to push the hub down and to the side to get the old axle out and the new one in. Make sure that you disconnect your brake line from all the mounts so you have room to move the hub.
Old Jul 12, 2016 | 09:02 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
I typically pop the two bolts holding the lower A-arm in place, pull the axle, and then put it back.
Old Aug 21, 2016 | 09:28 AM
dankaes's Avatar
Unbolt strut fron spindle
UNbolt brake caliper from rotor
UNbolt axle nut
PPush aaxle oout of hub
PPry aaxle oout oof ttrans
RRepalce
boarding2008
Jul 29, 2010 05:56 PM
minvi
Jul 28, 2010 11:44 AM
lowtegsr
Feb 1, 2008 07:18 AM
MartyPike
Honda Civic (2001 - 2005)
Oct 8, 2007 08:02 AM
