D16Z6 Skunk2 Pro Series Manifold throttle cable bracket?
Old Jul 9, 2016 | 04:04 PM
K-G's Avatar
K-G
Default D16Z6 Skunk2 Pro Series Manifold throttle cable bracket?
hey guys have a 93 civic d16z6 1.6l, ive had a pro series manifold & bigger throttle body for awhile now and no throttle cable bracket is really starting to bug me. ive looked around and cant seem to find a bracket suitable for the d16, only b series. Does anyone know what bracket i can use that will hold that cable correctly?
Pic for reference: https://www.google.com/search?q=skun...BRoLZKbewWM%3A
Old Jul 10, 2016 | 02:08 AM
K-G's Avatar
K-G
Default Re: D16Z6 Skunk2 Pro Series Manifold throttle cable bracket?
Any ideas anyone ?
Old Jul 10, 2016 | 03:53 PM
v4lu3s's Avatar
RTFM
what happened to the cable bracket on the original manifold?
Old Jul 14, 2016 | 08:49 AM
K-G's Avatar
K-G
oem manifold bracket doesnt fit the s2 mani holes. only one and its bent to hold the cable in place. its just annoying and would like to fix it with the proper piece. just havent been able to find it
Old Jul 14, 2016 | 08:51 AM
K-G's Avatar
K-G
actually i take that back. its not the bracket thats bent. just a piece of metal however, the stock bracket still never fit to begin with
Old Jul 15, 2016 | 05:18 AM
Beau Olivares's Avatar
I have a black pro series manifold and 66mm t.b on my z6 94 coupe i use the orginal intake manifold braket but i had to bend it shave a little metal off of a corner amd flip it upside down tho but it works just an idea
Old Jul 16, 2016 | 10:10 AM
24TEN's Avatar
PHANTOM MENACE
I had to do the same as well.
Old Jul 18, 2016 | 07:09 AM
K-G's Avatar
K-G
thats a great idea. i will have to try that. does your cars idle ever seem weird? or have the pedal stick at all?
Old Jul 18, 2016 | 07:10 AM
K-G's Avatar
K-G
do you guys think this bracket would fit? http://www.ebay.com/itm/like/281925195615?lpid=82&chn=ps&ul_noapp=true
Old Jul 20, 2016 | 08:01 AM
K-G's Avatar
K-G
Bump
Old Jul 24, 2016 | 09:02 AM
K-G's Avatar
K-G
B
Old Jul 24, 2016 | 06:05 PM
When i first did it the rubber grommet on the throttle cable stuck a little nothing to worry about tho.. But mine works great the way i ran it.. Ill see if i have a picture. Not the best pivs but hope hope they help
Old Jul 25, 2016 | 09:54 AM
K-G's Avatar
K-G
Word thanks those pictures help a bit ! Gives me an Idea where I can start
Old Jul 25, 2016 | 05:28 PM
My bad bro forgot to take new o es but hope these help even more the way im holding it is the way it was on my manifold
Old Jul 29, 2016 | 02:28 PM
94EG8's Avatar
Seagull Management
I know the ITR bracket works on the Skunk2 GS-R manifolds, and I'm pretty sure it also works on the LS Skunk2 manifolds. If The original D16Z6 bracket didn't fit (which incidentally is also the same bracket the D15B7 uses) and I had to take a random guess I'd try a P73 ITR bracket. Just so you know those brackets are only $13 at full list price from the dealer. Part number 16411-P73-000
Old Jul 30, 2016 | 12:07 PM
K-G's Avatar
K-G
Thank you very much guys!! It's very much appreciated. I'm going to do something sometime this week if it stops raining
lilo_goki
May 1, 2009 03:01 AM
sc34dx
Dec 15, 2007 07:11 PM
JDM00SI
Jan 22, 2006 02:06 PM
88 rex
Jul 9, 2005 07:33 PM
