ls b18a1 crx transmission - hard to shift
Old Jul 8, 2016 | 08:29 PM
90R3x's Avatar
Default ls b18a1 crx transmission - hard to shift
So my ls b18a1 crx transmission became hard to shift it has fluid and what happened was I was driving it was shifting just fine then I went to the gas station and the car was so hard to put into gear while car was on but goes into gear when car is off its a manual transmission.
Old Jul 8, 2016 | 09:16 PM
4drEF's Avatar
Keyboard Humorist
Default re: ls b18a1 crx transmission - hard to shift
Adjust your clutch cable.
Old Jul 9, 2016 | 12:31 PM
Former User's Avatar
Please help! please!
Please read the forum rules before you making another thread.
Old Jul 10, 2016 | 09:45 AM
90R3x's Avatar
Default Re: ls b18a1 crx transmission - hard to shift
How could it be the clutch cable? It was driving just fine then I turn it off at a gas station then it stopped going into gear after I started it back up. Everything was fine tell I turned it back on. Not making any weird noises or anything and also the car can go into gear when off.
Old Jul 10, 2016 | 10:55 AM
fcm's Avatar
fcm
Old Fart
At least check the cable, if good then you may have broken springs on the clutch...
https://www.bing.com/images/search?q...14&FORM=IQFRBA
Symptoms are easy to put in gear when engine not running but hard or impossible if engine is running, depending on how bad the damage is, [how many springs are broken]. 94
MastaFlyMason
Transmission & Drivetrain
Sep 23, 2017 03:58 PM
bk7794
14
Sep 7, 2012 07:17 AM
Clipsed
Nov 8, 2009 06:47 PM
Jdm_Rice_Monster
Dec 17, 2002 10:58 PM
yorace2win
Apr 4, 2002 08:47 PM
