Dual Bosch Pumps
Old Jul 6, 2016 | 04:37 AM
civic-r11's Avatar
Default Dual Bosch Pumps
I already have a inline 044 pump on my e85 turbo k20 turbo. I was wondering if anybody has used the dual mount 044 bump bracket mounted in the engine bay. I was going to run a "y" fitting coming from the intank pump to the dual bosch bumps mounted on the firewall, and another "y" fitting coming off the bumps to the fuel rail. I just thought this wouldn't be a bad idea.
What you guys think.
Old Jul 6, 2016 | 05:59 AM
jayswizz's Avatar
Default Re: Dual Bosch Pumps
if you are doing this because you need more fuel, this probably is not going to help, really all a inline bosch does for a intank pump is allow you to bump up pressure. your going to need volume if your out of fuel. idk what your looking for as far as power but fyi one walbro 450 hardwired with a big relay will make 750ish whp. if your looking for more than that i would go with a sumped tank with twin bosch OR a weldon/magnafuel unit.
Old Jul 6, 2016 | 06:20 AM
civic-r11's Avatar
I am trying to make around that. I just thought that would be fine to do this. I was also thinking about a surge tank setup.
Old Jul 6, 2016 | 06:58 AM
spoolinlude's Avatar
I live under a rock
I'm thinking you'd have better luck in upgrading your in-tank pump. With the 044, its basically a "lift pump" in place of a sump that you see on lots of cars. I'm thinking you don't want to sump the tank, if that's the case, I'd upgrade your in-tank to a higher flowing unit and consider upping your feed line size.
A surge tank is another great alternative, however more expensive.
Old Jul 6, 2016 | 07:17 AM
civic-r11's Avatar
Ok I got ya. I have a -6 feed line already on the vehicle. I am going to run the bigger pump intank.
Old Aug 8, 2016 | 08:36 AM
vento86's Avatar
ive got the IE surge tank with dual 044s.. 8an feed and 6 return. i wouldnt put the tank in the bay. not a smart idea. you can install the tank under the car. its small enough.
Old Aug 10, 2016 | 06:58 AM
extremeracer's Avatar
I have a surge tank installed which mounts between the chassis leg and rear bumper on my EG hatch, completely out of sight and in close proximity to the tank.
DW340 in-tank feeding the surge tank with 2 x 044's and 2 individual fuel lines running to the front and feeding each side of the Edelbrock rail. We drilled and tapped the FPR port on the rail for a -6 fitting to serve as the return = dual feed fuel system.
You can also run the two pumps to a distribution block or Y-fitting and then run one -8 line to the front like the 'normal' setup.
Old Aug 14, 2016 | 07:58 AM
civic-r11's Avatar
Do you have any pictures of where it is mounted? Do you have any fuel gauges or anything to monitor the other 2 pumps?
Old Aug 15, 2016 | 11:13 PM
Will check and upload...No just using the stock in-tank sensor, the system only adds about 3 litres to the total capacity.
viet_boi_racin
Feb 3, 2008 09:34 AM
iownanrsx
Jul 2, 2007 09:20 AM
hovic
Mar 12, 2006 03:43 PM
tegasaurus
May 6, 2003 04:59 AM
D-SPEED
Nov 27, 2001 05:22 PM
