b16 tranny, too short for turbo
Old Nov 7, 2002 | 07:10 PM
Dorikamu's Avatar
Default b16 tranny, too short for turbo
I am planning on running b18b turbo(t3) at 8psi, is b16a3 tranny too short for this set up, this is a daily driven car..
Old Nov 7, 2002 | 07:14 PM
DIRep972's Avatar
Smarter than you
Default Re: b16 tranny, too short for turbo (chusai)
what kind of racing are u going to be doing?
Old Nov 7, 2002 | 07:18 PM
DIRep972's Avatar
Smarter than you
if u dont care about doing high RPM's on the highway. and as long as ur car only traps like 100mph in the 1/4 then u could probably get away w/ it w/ out haveing to shift into 5th. if u trap over 100 at least get a GSR tranny. but the car would be hella fun w/ the b16a tranny, insanly short gears and good acceleration but very low top speeds for each gear w/ only a 7k redline.
Old Nov 7, 2002 | 07:40 PM
Pelican's Avatar
Default Re: b16 tranny, too short for turbo (DIRep972)
listen to him
but you could swap an LS 5th for highway driving. But you would still top out 4th at like 10xmph@8000 RPM. Not the best for Track
Old Nov 7, 2002 | 07:44 PM
SiRkid's Avatar
Default Re: b16 tranny, too short for turbo (Pelican)
oh , no, not this again..
lets try to leave it at direp's post
Old Nov 7, 2002 | 07:45 PM
Dorikamu's Avatar
what's the top speed on 5th gear on b16?
Old Nov 7, 2002 | 07:50 PM
HybridKOOP's Avatar
I just was at 8000rpm tonight in 5th in a '00 Civic Si and my speedo said 142.
Oh, and use the B16 tranny, don't list to anyone else. It's sweet. Ask Karl (Jinxproof) how it works for the 1/4 mile
- Louis
Old Nov 7, 2002 | 07:57 PM
SiRkid's Avatar
Default Re: b16 tranny, too short for turbo (HybridKOOP)
EXACTLY specially with slicks.
the top speed of the tranny is like 140-145 mph i think(actual) of course your speed is off at that speed.
ive hit 145 indicated before(no turbo) but im sure it was more around 130-135 as i still had rpm left and the gauge is off at those speeds
Old Nov 7, 2002 | 08:12 PM
Dorikamu's Avatar
Default Re: b16 tranny, too short for turbo (SiRkid)
alrite, thanks guys.. I dotn think I will hit over 130 in a EG...
I guys I will go with a b16 and see what happens.
Old Nov 7, 2002 | 08:29 PM
MotorMatrix.com's Avatar
I am a bad person
I'm running a type r tranny and If I'm correct they are are the same except for 1st which means nothing. My car is turbo and I love it. Mine does 140+ in 4th at 9800rpm. You'll get thru the gears quicker and stay in your powerband.
Old Nov 7, 2002 | 09:00 PM
Dorikamu's Avatar
Default Re: b16 tranny, too short for turbo (MatrixAutoSalon)
yeah. the problem is I can only go to 7k rpm.. since i have a B18b..
Old Nov 7, 2002 | 10:55 PM
Reilly's Avatar
It works fine for me. I have type r tranny, B18B with drag3. The only problem is the highway. I wonder how long it can handle 4500rpms for? But so far no problems. You shift alot, but if you like shifting(I do), you will like it. I have considered an LS tranny and putting in LSD though.
Here is a link to a good gear ratio calculator.....
http://www.autocrossing.com/cgi-bin/gearcalc.cgi
Old Nov 8, 2002 | 06:05 AM
Dorikamu's Avatar
Default Re: b16 tranny, too short for turbo (Reilly)
what mph is the 5th gear @4krpm
Old Nov 8, 2002 | 06:51 AM
rbf351's Avatar
i have the stock B16 tranny with a CTR ecu in my Si and 4th gear will top out at 125 at 8600 rpms
Old Nov 8, 2002 | 07:48 AM
Reilly's Avatar
Just over 70 mph. 70 is 3851rpm with stock 93 si tires.
Try the link I posted above.
Old Nov 8, 2002 | 07:54 AM
Reilly's Avatar
Default Re: b16 tranny, too short for turbo (rbf351)
what size tires do you have? You can check your speedo accuracy by going to tire rack, getting the rolling diameter of the tire, putting it in the calculator above, and comparing.
Old Nov 8, 2002 | 08:42 AM
SiRkid's Avatar
in my Si(R) im at 3400 rpm at 60 mph
DC5StylZ
Aug 17, 2006 03:07 PM
civicracer876
Jul 27, 2006 08:39 PM
CRAZYEG9
Apr 25, 2005 04:47 AM
jaydm ferio
Jan 9, 2005 02:34 PM
eg360B
65
Sep 29, 2004 12:49 PM
