experiencing lag! drag 3 turbo 00 si.
sup all! well i had this problem for quite a while now. all i have done to my car is colder plugs and everything that comes with a drag 3 kit. when i start off from 1-3.5k rpm at wot, my car feels very very laggy. the downpipe is connected to stock exhaust, do you think this can be the problem??? please respond!!! tahnx!
What is this crap?
Re: experiencing lag! drag 3 turbo 00 si. (pita106sg)
stock exhaust is actually bad for a turbo setup.
i thought it would be ok for me
lasted 3 days.
i thought i had a boost leak, but the turbo just wasnt spooling.
edit - when i say bad i mean harmful, since you will have a higher pressure in the exhaust manifold to sustain the same pressure in the intake. higher pressure = proportionally more heat, shortening the life of the turbo, and potentially the engine.
lasted 3 days.
Re: experiencing lag! drag 3 turbo 00 si. (Hammett)
couldnt a lighter flywheel help too. someone said that it makes it spool down too much when u let off but it should spool back up just as quick since its so light right?
oh yes exhaust should be first priority.
Re: experiencing lag! drag 3 turbo 00 si. (falconGSR)
Smarter than you
Re: experiencing lag! drag 3 turbo 00 si. (Mase)
as corky bell once said, not an exact qoute but "the best turbo exhaust is no exhaust!" haha back pressure is the enemy of a turbo car. by running a stock exhaust u r not only robbing urself of funfilled horsepowers, creating more lag, but u can potentially damage the turbo and the engine itself.
Re: experiencing lag! drag 3 turbo 00 si. (DIRep972)
really??!! thanks for the response guys! i dont have the cash right now for the exhaust but once i do get it i'll do it. i would run with just the downpipe but its way too loud for a daily driven car!. aahahah thanks all!
