Jdm b18b in 2000 em1. no spark
Hey there guys..I have a few questions about an em1 project that I've been working on. I picked up a 2000 civic si with a blown b16 and decided to swap in a Jdm b18b (obd2a I believe). Currently using the em1 harness on the b18b with an obd2b to obd2a harness adaptor to run p75-a04 (obd2a) from a 99 Integra ls. I currently have no spark and not sure what the problem is. Do I have to change anything with the distributor as far as wiring to get this to fire? from what I've been reading there is no immobilizer in this p75-a04. Any input to this issue would be much appreciated
The fuel pump does prime and there is one code which is p1298 eld high voltage when running the p75. My buddy let me try his p2t-a11 ecu and the car fires right up but idles rough and bogs under load. And no there are no blown fuses
There is a wire that needs to be jump in order for the integra ecu to run the car. Does your jumper harness have that wire re-pinned already?
shaylude01
93
Feb 2, 2012 09:16 AM
shaylude01
Mar 21, 2011 04:57 PM
