Gasket question
Old Jun 25, 2016 | 10:50 AM
chowderhead's Avatar
Default Gasket question
So I have oil in the 2 Spark plug tubes. I'm going to replace the seals but do I have to replace the valve cover gasket as well. Are gaskets seals only good for the initial seal?
My oil pan has a dorman rubber plug because I think the rapid oil change guys probably stripped the original plug. I was thinking of re-tapping it but doing it with the oil pan off. Again would I replace the oil pan gasket of I remounted the same oil pan.
Old Jun 25, 2016 | 12:14 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Default Re: Gasket question
You can probably get away with using the valve cover gasket again if it's fairly new and in good condition. I believe Honda sells the VC gasket in a kit with the spark plug gaskets and it's not that expensive. So why not just replace it?
As far as the oil pan gasket, I think it's a one time use.
eH.
Old Jun 26, 2016 | 09:32 PM
eghatch9295's Avatar
Stancetard Hate Monger
why in the hell would you reuse a god knows how old gasket? how much do you make an hour? i bet the time you waste doing this twice will end up costing you more than a couple gaskets.
walrus_07
Mar 7, 2009 01:21 PM
5Point7Liter
Mar 12, 2008 09:30 AM
thudreem
Oct 20, 2006 08:43 AM
teler86
14
May 18, 2006 05:18 AM
James
May 11, 2004 01:38 PM
