2000 civic SI won't prime with ignition
Old Jun 22, 2016 | 03:08 AM
TrueEm1's Avatar
Default 2000 civic SI won't prime with ignition
I recently came across an em1 that needs lots of love. There was no dash or wires. Bought an obd2b auto under dash harness online. Already bypassed clutch safety switch and it turns over but the main relay only clicks once. No fuel. Changed the main relay with a couple others I had. Same thing. I'm using a non vtec obd1 ecu with a jumper harness just for now to see if the swap is any good or what before moving foreward with the build.
Any suggestions
Old Jun 22, 2016 | 07:42 AM
Former User's Avatar
Default Re: 2000 civic SI won't prime with ignition
Check fuses 44 and 13.
Old Jun 22, 2016 | 08:52 AM
TrueEm1's Avatar
I downloaded the 2000 si service manual pdf and screenshot both fuse box diagrams. I dont see a 44 spot
Old Jun 22, 2016 | 09:59 AM
fcm's Avatar
fcm
Old Fart
Unplug PGM-FI Main Relay and check for the three(3) powers in plug...
1-12V + constant, [hot at all times] should be a yellow/white lead.
2-12V+ switched, [hot in run and start] should be a black/yellow lead.
3-12V+ switched, [hot when cranking to start only] should be a blue/white lead.
Also check for continuity to chassis ground on the black lead, [should be good as you do heat one click from PGM-FI Main Relay.
If all good plug relay back in, turn ign. on and supply a ground to the green/black lead, [ECU fuel pump relay control lead]. 94
Old Jun 22, 2016 | 11:28 AM
You have the wrong fuse box diagrams.
Old Jun 27, 2016 | 01:51 AM
TrueEm1's Avatar
Where's the 44 spot?
Old Jun 27, 2016 | 04:34 AM
tony_2018's Avatar
Fish Twig
Engine bay, it states it in the image
davidayala831
May 22, 2016 08:53 AM
ThatGuy4life
Feb 5, 2007 08:53 AM
B16aSir2
29
Jul 30, 2006 10:53 AM
gutted-dx
18
Jun 21, 2005 03:34 PM
USAFgunner
Jan 29, 2005 09:36 PM
