ignition/key issues
Old Jun 16, 2016 | 06:54 PM
jneiss19's Avatar
Default ignition/key issues
hi guys,
odd problem here. my key wouldnt come out of the ignition unless i unhooked the negative battery cable. it did a few times with wiggling the key and hitting the console and trying a million times.
I figured something was jammed up, it is a 20 year old car after all. i sprayed some pb blaster on the key, inserted the key, repeated this 3 times to get a decent amount of lube in there. key was coming out with all sorts of black crap on it so i wiped it off when i took the key out.
now the key wont turn at all. its a pretty worn key so im thinking maybe since i cleaned it out in there, the crud mightve been helping the worn key work and now that its gone thats not the case.
ive taken the cylinder out of the ignition and it wont turn even in my hand.
any ideas?
Old Jun 16, 2016 | 08:04 PM
jneiss19's Avatar
Default Re: ignition/key issues
update, upon further disassembly of the cylinder it seems the tumblers are worn and not retreating fully. hopefully some cleaning and light filing will help. im a mechanic, not a lock smith lol.
Old Jun 16, 2016 | 10:33 PM
jneiss19's Avatar
worked like a charm...total PIA though
Tank_EM2
Honda Civic (2001 - 2005)
Aug 22, 2014 08:31 AM
bfpicard
Mar 17, 2014 07:44 AM
d15b7racer
Nov 21, 2005 02:48 PM
qcktegls
Jan 9, 2005 03:52 PM
Lude-Conduct
Nov 4, 2003 07:55 PM
