Need an answer about Base to SH swap
Old Nov 7, 2002 | 03:45 PM
GruvyTune's Avatar
New User
Default Need an answer about Base to SH swap
I really hope someone can answer me about whether a base engine/tranny/transaxles will mate up with the SH suspension/hubs. I did numerous searches but no one can come forward and say that they have actually done it or whether it will DEFINITELY work!
thanks.
Old Nov 8, 2002 | 04:41 AM
GruvyTune's Avatar
New User
Default Re: Need an answer about Base to SH swap (GruvyTune)
anyone?
ttt
Old Nov 8, 2002 | 06:38 AM
GAperformance's Avatar
New User
Default Re: Need an answer about Base to SH swap (743lude)
Don't waste your money. If you want great handling get a TEIN setup and an LSD. You will be able to pull corners better than any SH.
Old Nov 8, 2002 | 07:45 AM
GruvyTune's Avatar
New User
Default Re: Need an answer about Base to SH swap (bkw97lude)
come on now...this is not that complicated!! I got an sh on a good deal from a dealer. My integra was stolen prior to that. I'm planning a rebuild on an H22 and the sh wont handle the high boost without ATTS going ballistic.
So, I'll be taking the engine out anyway! Why not build up a base engine and put a quaife in the base tranny and then when I'm done swap it into my SH car???
So, All I really need to know (not that I don't value all your other responses) is whether I can expect the base engine/tranny to bolt up nicely to the SH suspension.
Old Nov 8, 2002 | 12:13 PM
Sticky Tires's Avatar
* B A N N E D *
even if the SH has Teins too? yall can't **** with ATTS! come drift with me and you'll see I'll rape any sucka with LSD, just the other day i raped a GST doin 50 into a corner. it was butters baby.
Old Nov 8, 2002 | 03:01 PM
jc836's Avatar
One of the reasons no one recommends this is the way the chassis is setup. The suspensions in front are NOT the same and are NOT interchangable without a lot of work. It may be possible-if you have the resources to remove only the ATTS, rewire everything-including the computers, and then you would still have the SH front suspension components to deal with. I am simply saying that machine shop time is very expensive as is having a pro redo the chassis.
Old Nov 8, 2002 | 03:47 PM
GruvyTune's Avatar
New User
Default Re: Need an answer about Base to SH swap (jc836)
but wait, what is so different about the chassis/suspension that doesn't allow the base tranny/transaxles to go into the hubs?
UniqueX707
Nov 6, 2014 04:01 AM
vectorsc
Apr 16, 2008 04:17 AM
pacmann_9595
May 8, 2006 04:17 PM
ildknyli
Oct 9, 2003 08:01 AM
GruvyTune
Nov 3, 2002 07:03 AM
