12:1 FMU with stock injectors...how much boost before injectors blow up?
89 crx with d16a6, 14b turbo, starion i/c, 12:1 FMU with inline fuel pump.
how much boost can i run before i have to worry about the stock injectors floating? should i just go for the SMC with 450 injectors? does anyone have ACTUAL experience with the SMC?
Smarter than you
I would rather not find out. injectors usually seize from high pressures.
ineed somthing like 340s that will idle with stock ecu... hmm that enough for 6-7psi on H23 motor without vortec?
Layziebtnh055
Oct 9, 2004 03:48 PM
