Crank pulley keeps coming loose
If it has been running loose, at least replace the pulley so that the hole is the right size. And hope the crank isn't too messed up.
Bolt tightness spec is 140 ft-lb. Or tighten to 14 ft lb then put an impact on and turn 1/4 turn additional. The latter method might not work properly if the parts are torn up already.
bradley
13
Jan 9, 2012 02:12 PM
