Crank Pulley Bolt -?
The crank keeps on spinning. I put it in park/r/d and step on the brakes but the crank keeps on spinning. It is an automatic of course.
I have a 4" Breaker Bar using 1/2 extension. I tried to take out the starter and stick something in there but I couldn't get a good grip.
Is there a special way for automatic integras to prevent the crank from spinning?
Re: Crank Pulley Bolt -?
the concept behind that thing is to fit in the crank pulley and allow you to put a driver end of a breaker bar or wrench in the square hole. you wedge that against the ground and a socket fits inside the larger hole to work on the crank pulley bolt.
an impact wrench has enough torque to loosen the crank pulley bolt without a lock tool like the one that is pictured above. i changed front wheel bearings on my automagic last summer that way, and the only time i needed my gf to hold the brake pedal was for the axle nuts.
is there any other way to prevent the crank from spinning for automatics? i have a strong enough breaker bar but i dont know how else i can stop it from spinning
^ basically that
an impact works most of the time. i did however have a jdm engine once that came right off the boat that wouldn't come off for ****. tried propane, breaker bar, all of it. i wound up having to rig up a fixture that put bolts into the crank, welded it to a wrecking bar, braced it into a wall and stood on a 2ft snap on breaker bar on that crank bolt jumping up and down
bradley
13
01-09-2012 02:12 PM
