95 Civic cranks but won't start
Old Jun 5, 2016 | 04:55 PM
moyospeed's Avatar
Default 95 Civic cranks but won't start
Thanks in advance for any answers. I've searched and searched the past few days.
95 civic hatch-d15b7 all stock.
Has fuel at fuel filter, and it's reaching the spark plugs.
Has spark and I checked with a spark plug tester.
Turn key to on(ii) position hear fuel pump hum and cel goes away after two seconds which I hear both of these mean working main relay.
Battery voltage is good, when checking spark plugs for spark they seemed really old and crusty. I just bought the car and judging by the looks I wouldn't be surprised if they were factory lol.
Here's the weird part, after checking everything and putting it back together. I tried jump starting a few more times. I read about a clear flood mode on here and held the throttle down...it speeds up and sounds as if it may be doing something close to cranking. Each time it sounds closer. Just gave it one last go with what battery I had left and it almost started. What exactly would cause this??
SHORT VERSION---- turns over but no start, holding throttle sounds like it just might start. Going to buy plugs and wires in the am and try.
Old Jun 5, 2016 | 05:21 PM
tony_2018's Avatar
Fish Twig
Default re: 95 Civic cranks but won't start
Originally Posted by moyospeed
Battery voltage is good, when checking spark plugs for spark they seemed really old and crusty. .
Old Jun 5, 2016 | 06:51 PM
moyospeed's Avatar
I plan on replacing them in the morning. The car ran and the next day it didn't. Maybe a dumb question but is it common for all of them to stop working regardless of condition?
Old Jun 5, 2016 | 07:02 PM
Former User's Avatar
Default Re: 95 Civic cranks but won't start
Check the mechanical timing, and compression test the cylinders.
Is spark bright white at all 4 plugs?
https://honda-tech.com/honda-civic-d...blems-2919450/
Old Jun 6, 2016 | 05:35 AM
moyospeed's Avatar
The spark was white and blue but maybe I'm blind but it seemed to have some orange in it too. I also checked spark off the coil and it was almost all orange. I plan on checking mechanical timing and testing the distributor more if the plugs don't work. I have a multimeter and test light.
Old Jun 6, 2016 | 05:46 AM
SpeedRacerEX-R's Avatar
Did you wake up one morning and it didn't start, or did you do some work to it and it didn't start?
Old Jun 6, 2016 | 07:07 AM
moyospeed's Avatar
Just woke up and the next day it would not start.
Old Jun 6, 2016 | 08:40 AM
tony_2018's Avatar
Fish Twig
I'd start with the ignition system first.
Old Jun 6, 2016 | 09:41 AM
moyospeed's Avatar
New spark plugs held throttle it cranked finally after a few tries. Idles although when coming to a stop and pressing the clutch it wants to die, but after tapping the gas it idles just fine. Cranks back up fine too thanks every body I'm hoping more maintenance parts fixes the coming to a stop issue.
Old Jun 7, 2016 | 11:29 AM
Dilbones's Avatar
Had the same problem with my Civic. Assumed it was something way worse than what it was.
Check your clutch bypass switch
Jumper that bish.
Old Jun 7, 2016 | 03:27 PM
collkid's Avatar
Main Relay?
Old Jun 9, 2016 | 04:25 PM
moyospeed's Avatar
Once I got it running and new spark plugs it runs fine now
amoeba2315
Oct 31, 2024 07:55 PM
civic2sick
Feb 26, 2020 09:39 PM
hamburgler
Aug 21, 2011 10:23 AM
97accord_R
Aug 30, 2009 06:51 PM
