97 Civic EX - Emissions test high HC and NOx
Stancetard Hate Monger
Currently helping a scientist (not really) who for some reason allowed his 97 Civic to be tested on the rollers instead of the obd-2 port. Car is a stock EX, has no CEL, and obviously would have passed the port test. It failed the roller (sniffer) test in a pretty impressive fashion. HC and CO are way up, was slightly over on NOx. Aside from adjusting ignition timing, verifying ignition components condition, and changing the oil (its bad), what else should I look for to get those numbers back down?
if i can get my hands on it, i will. was texted to me in the following format:
hc 97lim- 272
Co 54lim- 353
Nox749lim- 924
hc 97lim- 272
Co 54lim- 353
Nox749lim- 924
If the car has an EGR system, cleaning the EGR valve and passages is important for NOx. Failing all three often means that the catalytic converter is worn out, that may also eventually throw a P0420.
Some maintenance tune up work will probably need to be done. fuel injection cleaner should do the trick or pull them out and send them off to be clean and tested. Ignition system can probably need some replacing as well.
im going to replace the plugs, swap the working autozone reman dizzy for a known good oe, and retard the ignition timing. retest after those things, will post results. im sure people will question the dizzy swap, but reman units are pure trash. instead of bench testing every component in the POS, i will use one of mine to be sure i have a 100% working unit.
No doubt, my cousin autozone crap died on him not too long ago. He ended up having to replace it again...again....again....until finally 1 kept running
changed oil, swapped distributors and wires for a set of ngk's, retarded ignition timing significantly. nox nearly cut in half, hc/co both reduced but still way above limit.
egcivic775
Jun 16, 2017 05:35 AM
Soup Slayer
Oct 18, 2013 01:53 PM
kurrupt626
Oct 23, 2011 11:25 AM
renelimabr85
10
Feb 19, 2010 10:35 PM
