97 Civic with D16Y7 engine wont start
Left my neighborhood a couple weeks ago and i quite on me
replaced the dizzy thinkin that was it
found out it wasnt turnin
realized the cam had broke in half
replaced it and it still wasn't runnin right so i pulled the head and it had 2 bent valves
replaced um put it back together and it still wasn't runnin right so for ***** and giggles i pulled the exhaust manifold back off sure enough it ran like a charm
so iv bought a header to get rid of the clogged cat
put it on and now it wont start so im guessing i unhooked something or theres a code of some sort that needs to be cleared im not sure
Last edited by Former User; Jun 4, 2016 at 08:05 AM. Reason: Use punctuation or break up your text to make it readable
Add required car information.
Test for spark and fuel.
https://honda-tech.com/honda-civic-d...lists-1901557/
And its not throwing codes because it hasnt ran for it to actually throw one
How did you check for spark? In all 4 cylinders? How did you determine quality of spark?
Does the fuel pump prime? Do the injectors spray fuel?
Post pics of the cam and crank at TDC1.
The engine doesn't need to run for the ECU to throw codes. Check for codes.
If you're unwilling to provide basic and verifiable no-start 101 diagnostic results, then this thread will be locked.
For what it's worth, I was mystified for over a month as to why my Civic wasn't starting. Confirmed spark on all 4 cylinders, confirmed injectors were spraying a nice plume of fuel (took the whole rail off and cranked the car), confirmed compression was good, confirmed timing was dead on, no CEL...turned out the spark plugs were fouled. Outside the car they had spark (orange spark, not great) but once installed the compression and/or massive amounts of fuel was enough to blow out the spark. Changed plugs and it ran like a champ. Got a different chipped ECU to put my chip in and that fixed the running rich condition that led to the plugs fouling.
Just goes to show you that sometimes even when everything SEEMS good, sometimes it's just not QUITE good enough to run the car. If your plugs are black, you may have too much fuel getting in, which also could have caused your catalytic convertor to melt.
Wrona
Feb 6, 2011 02:56 PM
NGAMotorsports
May 16, 2008 06:54 PM
