T25 on stock y8 motor
Old Jun 3, 2016 | 04:32 AM
nokehockey20's Avatar
Default T25 on stock y8 motor
Would a t25 turbo be good for a stock d16y8? The car will have bigger injectors and chipped ecu and a tune. But since the stock rods handle about 240-250hp would the t25 do the job? I know its a pretty small turbo, Realistically only wanting to make about 200-220. Woild the turbo be just about maxed out making those numbers? Just would be nice to merge onto the highway without having to floor it and turn the ac off to not get hit. Thanks
Old Jun 3, 2016 | 05:27 AM
Schister66's Avatar
Man U FTW
Default Re: T25 on stock y8 motor
Depending on which T25 unit you use, you can easily make that power. The trick is finding a decent T25 flanged manifold for your Y8
Old Jun 3, 2016 | 06:39 AM
A buddy of mine has one of those adapters t25 to t3 flange. J know there's always that possibility of a leak, but I would think it will still work
Old Jun 3, 2016 | 08:50 AM
TheShodan's Avatar
Moderator
Make sure the T25 you get doesn't have a radius flange
Old Jun 3, 2016 | 08:59 AM
you mean like the dsm t25 turbo? this looks the exact same as t3/t4 just smaller
Old Jun 3, 2016 | 12:06 PM
2kdrift's Avatar
I had a t25 on my Z6 motor it was lots of fun just not so great on the top end.... 1st-3rd it was real peppy. Never got it dynoed but it was prolly in the 200-220 range
250HP on a stock Dseries is not "safe" IMO
Edit: I was never able to nail down the specific turbo I beleive it came off a SR20 if that helps, Intercooler was a DSM sidemount spool was crazy fast much like a supercharger
Old Jun 3, 2016 | 12:16 PM
TheShodan's Avatar
Moderator
Yes. But if not, it may have been a SAAB, or Volvo, which are usually in better shape
Old Jun 3, 2016 | 02:47 PM
Handerp's Avatar
You'd be fine with a small dsm/volvo t25. Just go for 200whp and she'll chug along just great for daily driving and spirited driving.
Old Jun 3, 2016 | 03:36 PM
Sounds good, what is a good safe amount of boost for these turbos? I know 6-7psi is a lot less power than that of a bigger turbo so what would be the best range? Don't they just about max out around 14-15 anyway?
Old Jun 3, 2016 | 03:38 PM
Handerp's Avatar
That would be up to your tuner. He'll turn it up or down.
boosted_D
Mar 11, 2012 06:44 PM
Frost7177
Jan 16, 2007 10:54 AM
Vtakkk
Jul 4, 2006 04:53 PM
clutch33
Feb 28, 2004 07:32 AM
solsteeler
May 16, 2003 07:44 AM
