RPM too high
Old May 29, 2016 | 08:52 AM
Latiff119's Avatar
Default RPM too high
Every time i gently put my foot on the petal it takes about 5 seconds until the RPM is as high as 4000-7000 and I can only be driving 25mph. Why?
Old May 29, 2016 | 09:23 AM
StokelesS_g2's Avatar
Default Re: RPM too high
Because ur K swap is too powerful.
Old May 29, 2016 | 09:39 AM
Latiff119's Avatar
by any chance can it be the throttle position sensor?
Old May 29, 2016 | 12:58 PM
GhostAccord's Avatar
Well considering you gave us absolutely no information on what model or year you are having an issue with?????
First thing to check would be your throttle cable for proper tension and smooth operation. Then you can start looking at electronics.
Once we know what year your car is, there are a couple different ways to check other things.
Old May 29, 2016 | 04:26 PM
Latiff119's Avatar
2000 honda accord lx 4cylinder
Old May 29, 2016 | 05:40 PM
In that case check your throttle cable. If that is ok, hook her up to a scan tool and che k the live data for TPS response. While it's hooked up, if the TPS checks out ok, you can monitor other sensors. I.E. engine coolant temp.
Is your check engine light on?
vr4twinturbo
Jul 25, 2017 07:57 PM
Jaymon
14
May 24, 2015 11:59 PM
jdmsir96
Jan 7, 2008 04:59 PM
marcelo17
Apr 30, 2005 09:17 PM
mario82686
23
Jun 24, 2004 02:03 PM
