Supertech Pistons, Buddyclub Spec3+ cams (B Series)
Supertech Pistons - 81.5mm should yield 12.5:1 compression
These were installed, but never run so essentially brand new. Absolutely nothing wrong with them, installed / removed professionally, rings are set and ready to drop in.
$325 + shipping
Buddyclub Spec3 camshafts - Used but in good condition. Great N/A cams.
$350 + shipping
These both came in a sleeved motor I purchased from someone locally who didn't finish a build. I purchased it with the intention of replacing the pistons / cams in favor of something a little more boost friendly.
$325 + shipping
$350 + shipping
What valve train did you run with those cams?
I remember some BCs cams they worked with stock ITR valve train but not sure if it was the BC3 or BC3+
You sure these are spec3+ cams? It's a little hard to tell the marking from the pic, but i have spec3+ cams and they cam with a "T" on the ends.
Na-TiffeR
Apr 28, 2015 01:33 PM
battle2.0ek9
Apr 27, 2007 05:01 PM
