92 civic d15b7 head swap
I'm swapping the head from a d15b7 to a d16y7 head. I'm sure I need to use the y7 cam gear and the y7 belt. My question is how to time the two together. I've read that one belt is shorter than the other and the cam gear needs to be set different. But I haven't found anything that was exact how to. Is there anyone who can shed some light to timming a y7 head on a b7 block
The key here is not to expect the UP and side markers of the cam gear to line up like factory.
You first put the cam TDC with the Y7 gear with the up and the side markers like you normally would via the FSM. I would do this without the cam bolt installed so that you can take the Y7 gear off without turning the camshaft at all.
Now you can slide the B7 gear on and I would probably add my own side markers on the B7 gear so that I had some sort of TDC marks on the B7 gear that correlate to your custom setup.
Tighten the cam bolt and you have the B7 gear on the camshaft in TDC position.
I, like you, am assuming the half tooth variance from the deck height will also be present in your setup like it is on the mini-me setups. It just may be on the opposite side (retarded vs advanced).
The fix for the half tooth is normally using the opposite gear to the head (obd2 gear on obd1 head and vice versa).
You will know for sure once the head is on and you run either belt from the crank gear up to the cam gear. If the teeth mesh, then you are not off. If it's half a tooth off, then the opposite gear should compensate.
As for which belt, you want the belt that is not too tight. I don't actually know how many teeth are on the Y7 belt. And I'm foggy on the B7 belt but I think it's 106 teeth but could be mistaken. Really, the teeth distance is the same between belts so changing teeth count won't affect timing, it only effects tightness and looseness of the belt. Too loose and it can skip teeth, too tight and it puts added stress on bearings and such. I think the tensioner can make up for some slack but not sure how loose is too loose.
You are going a direction a bit different than the typical tried and true methods. I have not seen much documentation of any of putting the non-vtec obd1 head on an obd2 block.
I've always read that the Y7 and Y8 blocks are nearly identical, and you even state the Y7 belt is the same as the Y8 belt which would also indicate the same thing to be true.
Here is some additional information on timing belt options quoted from this post:
https://honda-tech.com/honda-civic-d.../#post12322998
What is interesting about this is the D15B7 has a shorter deck height of 10MM ovedr the D16's. And yet, the timing belt is 2 teeth longer over the D16's.
Now quoting this post on D-series:
How to mechanically time a mini me swap/ other mini me info - D-series.org
Seeing the tooth count difference between the D16's and the B7 of 2 teeth even though the deck height is taller by 10mm on the D16's makes me think the water pump is laterally out farther requiring the longer belt.
The deck is only dropping 10mm so I suspect the ideal belt would have 105 teeth.
Now is it better to be 10mm tighter on the belt than ideal or 10mm looser on the belt?
Or am I just waaaaay over thinking this?
Originally Posted by firsteg
On a d16y8 or d16z6 (any normal d16 for that matter) the deck is 212mm
Whereas the deck height on any normal d15 is 207mm
This is a difference of 5mm
how much to adjust the cam
I measured the teeth off of my old timing belt and I got 11 teeth for 10.5 cm so we can pretty much call that each distance between peaks of the teeth is 10mm
5mm is half of 10mm therefore ½ tooth
every one of these i've done tension properly with the 104 tooth belt. back in the day of mini me's being on the cutting edge, a lot of guys went with the vx 103 tooth belt, only to find it was too tight. 106/7 is too slack, 104 works perfectly.
yeah, ooops.
Yeah, I've seen a few people say they VX belt (103 tooth) was too tight. And also seen everyone seems to run the 104 tooth belt.
Was just looking at it mathematically and couldn't even do simple subtraction.
20mm (2 teeth) - 5mm (deck height variance) ends up being 15mm tighter belt using the 104 tooth belt on the B7 block D16 head.
Thinking about that and everyone's experiences. If 5mm looser makes the belt too loose, then it sounds like the stock B7 is a bit looser of a belt to begin with.
I still think ideally a 105 tooth belt would be the near perfect fit but that's not the typical options in the 92-95 era if at all. And since the 104 belt works well there's no need to go digging any further really, except for fun.
20mm (2 teeth) - 5mm (deck height variance) ends up being 15mm tighter belt using the 104 tooth belt on the B7 block D16 head.Thinking about that and everyone's experiences. If 5mm looser makes the belt too loose, then it sounds like the stock B7 is a bit looser of a belt to begin with.
LoL
I went..... and pretty much a bust if you wanna stick to Honda.
Hyundai Accent seemed to have a 105 tooth belt with proper pitched round tooth but it's thinner and suspected not as strong.
How ever in that read, another interesting piece is the tensioner being swapped out has an effect on belt tightness.
Seems on the A6 block with the Z6 head, you use the Z6 belt but you have to also use the Z6 tensioner or it's waaaay to tight with the A6 tensioner.
That being said, the A6 tensioner may take up the slack on the B7 belt if required.....
Dunno, might be something to try sometime.
Last edited by TomCat39; May 27, 2016 at 05:40 AM. Reason: Forgot to share that I laughed pretty hard.... Adding the LoL
ive been after a decent a6 block for awhile, and that is the head i would use. if i can ever get my hands on one, ill let you know.
It does seem odd that a Z6 tensioner would fit an A6 block but not the other way around.
This is the thread, that tidbit is in post #9 the Hyundai belt is in post #2 and then the follow up about strength being questionable is post #15:
a6/z6 timing belt? where to find 105 tooth? - D-series.org
gramentz
Aug 31, 2013 09:44 AM
