99 Civic with idle problem
I have a high idle and idle surge issue. Ive cleaned the iacv and replaced coolant temp sensor still no change. Have checked all the vacumm hoses for leaks and they seem to be good. Not sure what is going on but its driving me nuts
A ton of different things can cause a high idle. The most common being a vacuum leak, throttle body issue, or the IAC. If the coolant temp sensor was bad the car will generally idle fine after it has warmed up. For Vacuum leaks there are other things other than the vacuum lines that can leak such as the intake itself.
Did you have codes or did a scan tool indicate the coolant temp sensor was reading faulty?
This will need to be diagnosed properly as so many different things can contribute to the high idle.
This article explains well causes of a high idle. https://www.yourmechanic.com/services/engine-idle-speed-is-high-inspection
Good bet is on Idle Air Control Valve if you checked vacuum lines are all connected and sprayed starting fluid along them with no effect
If you cleaned the IACV before this started or got worse, you may have actually dried out the bearings in it and froze it like I did to mine
You can pick one up new on Ebay for real cheap- just always look for a seller with lots of positive reviews!
(I got an OE one new on Ebay from China for $30 which fixed mine bouncing 3k to 1.5k rpm nonstop in park/N but running totally fine in gear)
my $.02
also, if you pulled the throttle-body to clean it or or the IACV, make sure you get an OEM TB gasket for it if you didn't at the time
my $.02
