Condenser fan
Old May 15, 2016 | 09:29 AM
Wynter's Avatar
Default Condenser fan
2000 honda accord. Condenser fan not working but radiator fan it's still working. Fan does work if you straight wire it. Changed the relay out and it still does not work. All fuses are good related to condenser fan as well. Using test light I can not get any power to the condenser fan plug or wires that connect it. Any ideas what to check? Thanks!
Old May 15, 2016 | 11:40 AM
StokelesS_g2's Avatar
Default Re: Condenser fan
Is your AC on?
Old May 15, 2016 | 11:45 AM
Wynter's Avatar
Yes a/c is on and working fine until you stop at a red light and the temperature starts climbing from the fan not working
Old May 15, 2016 | 02:18 PM
holmesnmanny's Avatar
It's likely there is a wire open somewhere. It might be wise to have an electrical shop trace it.
Old May 15, 2016 | 05:32 PM
Your fans should kick on when the AC is turned ON.
Kevonn Martin
Apr 26, 2018 08:03 AM
Hobkins
Oct 15, 2012 04:57 PM
josemt
Jun 23, 2010 06:24 AM
976
Sep 9, 2001 08:22 PM
rtype11
Jul 11, 2001 10:16 PM
