94 Civic Ex - Tranny popping
Old May 13, 2016 | 09:37 AM
wikd3's Avatar
Default 94 Civic Ex - Tranny popping
I've got a 94 Civic Ex. I parked it a couple of weeks ago when I started hearing a popping that I thought was coming from the cv axle. Replaced the cv axle on the passenger side. Still doing it. Its a really loud and constant popping when the wheels are rotating. Anyone know what it could be? Thanks.
Old May 13, 2016 | 09:45 AM
eh2_Trav's Avatar
Default re: 94 Civic Ex - Tranny popping
So its making a popping noise when you drive straight? Sounds like they may be possibly binding or your wheel bearing is bad but ive never heard of a wheel bearing "popping" when bad though. put it on jacks and try to just spin the tires with your hands to dial in on the sound. thats my 2 cents
Old May 13, 2016 | 10:29 AM
wikd3's Avatar
When I change the cv axle I had it on jack stands, put in gear and it was still doing it. It sounds like it's either coming from the tranny or cv axle, changed the passenger cv axle, I'd rather not change the driver side if it's a tranny issue and not the cv axle.
Old May 13, 2016 | 10:31 AM
Former User's Avatar
Auto or manual trans?
Get an engine stethoscope and pinpoint the noise with the front end on stands.
Old May 13, 2016 | 02:11 PM
wikd3's Avatar
Manual trans, if I used a stethoscope I'd probably go deaf, it's a very loud popping
Old May 13, 2016 | 02:22 PM
Default Re: 94 Civic Ex - Tranny popping
Choose whatever method you like to pinpoint the noise, but that's what's needed to identify the cause.
Old May 13, 2016 | 02:48 PM
wikd3's Avatar
I know it's definitely either the cv axle on the driver or something in the trans. When we had it jacked up, only the passenger side wheel was rotating when I gave it gas. I was told that's the way it's supposed to be, positive traction. So, with that being said, it seems to me that it's something in the trans once the driver side isn't supposed to turn with out traction. Just wondering if anybody has had this problem and could tell me what it is. I don't have the time or money because of work and kids to tear stuff down that doesn't need to be tore down or replace things that don't need to be replaced. But if I have to, then so be it.
Old May 13, 2016 | 02:54 PM
Members can't tell you with any confidence what the problem is because they are not there to inspect the problem.
I've suggested how you can pinpoint the problem. If you won't take advice, then proceed how you see fit.
Old May 13, 2016 | 04:15 PM
burnoutboy's Avatar
The Credible Hulk
Is it pooping in the bathroom of it's natural sex or the sex it identifies with?
Oh.... popping.... my bad.
Old May 13, 2016 | 05:21 PM
wikd3's Avatar
It's not tuned for drag, so I'm gonna say natural.
Old May 14, 2016 | 09:02 AM
eh2_Trav's Avatar
I once had a bad input shaft bearing that made a terrible noise when i let off on the clutch pedal. I thought i had a rod knock it was so loud. But i pinpointed the issue and changed out the bearing. the sound was coming from where the engine mates up with the transmission. but without knowing this is purely a guess or something you can read and exclude as the problem. the input shaft bearing is a common problem with the y8 transmisson
Froggy85
Apr 16, 2018 12:42 PM
Froggy85
Mar 19, 2018 06:44 PM
liquidzorch
Transmission & Drivetrain
Apr 18, 2013 05:29 PM
blasterman87
Nov 30, 2009 08:09 PM
mtownsi
Aug 5, 2007 02:38 PM
