94 civic ex lowered cv axle problem?
I have a 94 ex sedan I put truhart lowering coil over suspension on it sits like 6"or so off the ground my old cv axle pulled out of transmission on passenger side it needed to be replaced boot was tore up, but anyhow now with new one put in it pulled out again how do i stop this from happening anyone ever have this happen?
Re: 94 civic ex lowered cv axle problem?
I pushed it in tI'll I heard it click in. I was wondering if there is something im not doing right? Could it be because it's so low I like the height it sits at but I don't wanna keep dealing with the axle pulling out anymore
Lowering the car wouldn't have anything to do with it. Pulling out too far on the wheel end of the axle would first pull the inner joint apart. The "cup" part of the inner joint would stay in the transmission.
When the axle is properly latched into the transmission, it will not be able to be pulled out by hand or by lightly prying on it.
You are certain it is the correct length?
once fully inserted into the transmission, it doesnt pop out easily. It will take some force to get it to come out.
ensure the c ring is still on the shaft. Push it in all the way, turn it a couple time.. pull on it, if it pop out, then it is not seated all the way in.
Froggy85
04-16-2018 12:42 PM
