rust inside rocker, interior panel
You really can't. If it's not bad you can spray something like Rust Check/Krown/Fluid Film in there or some other oily type undercoating and it will drastically slow down the progression of rust. If you really truely want to stop it you'd have to drill out the spotweld, separate the pieces, sandblast everything, paint the inside with epoxy primer and then weld it back together, and again fill with some sort of oil based undercoating
t0ny
95
Oct 6, 2010 04:21 AM
nix94delsol
Apr 17, 2007 06:48 PM
vandersmissenc
Dec 10, 2006 03:40 PM
