Suspension & Brakes Theory, alignment, spring rates....
95 sedan rear disc
Old May 12, 2016 | 07:55 AM
thorton21's Avatar
Default 95 sedan rear disc
I have done quite a bit of research on the rear disc conversion on the 95 civics, but I everything I have found so far have been for either a coupe or hb.
My question is, would all of that apply to a sedan as well or is there anything that would be different?
If anyone has a link to something that I may have missed, that would be appreciated also.
Old May 12, 2016 | 04:29 PM
Calif_Kid's Avatar
Default Re: 95 sedan rear disc
I doubt that there is any difference in the parts needed for a sedan vs a coupe or hb. I'm not sure if you've seen it, but there is a lot of good info (for front and rear brakes) in the thread https://honda-tech.com/suspension-br...egras-3044628/ which is up in the Sticky section of this Suspension & Brake forum. - Jim
Old May 12, 2016 | 05:58 PM
thorton21's Avatar
I have read that one, I didn't really see much about a sedan though, that's why I asked. Thank you for the advice.
Old May 12, 2016 | 06:28 PM
Cobb2819's Avatar
Sedans are the same but e-brake cables need to be from a sedan. Grab those off of an Integra Sedan, and I think you're good to go.
Old May 12, 2016 | 07:54 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
The 1995 Civic EX sedan with ABS came with factory rear disc. Just find one in a junkyard and take everything you need including the parking brake cables.
You can use the rear disc trailing arms from any 92-95 Civic, 94-01 Integra or 94-97 Del Sol VTEC. Get the cable from another Civic sedan or buy them new.
eH.
Old May 14, 2016 | 04:08 AM
spAdam's Avatar
Loved
Community Favorite
Note, anything that applies to the coupe applies to the sedan.
Ebrake cables from an abs equipped 92-95 Civic EX coupe/sedan OR a 99-00 Si coupe are what you are looking for.
Old May 16, 2016 | 10:02 AM
thorton21's Avatar
Would I have to convert to abs for that to work?
Old May 16, 2016 | 12:06 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
No. Parking brake cables have nothing to do with ABS.
eH.
66fasty
May 2, 2007 03:58 PM
BlueTeg
11
Aug 25, 2005 10:43 PM
IT'S ME DAVID
Jul 26, 2005 10:17 PM
oxSLEEPERxo
16
Apr 8, 2005 07:40 PM
