93 accord transmission mount replacement
For some reason the mount on transmission won't come out its stuck on the last stud by a thread and was wondering if the starter would have to come out inorder to replace it
i dropped my front mount and lowered my driver mount, lowering the motor and trans for extra room and used prybars to get it out,oh and i pulled the battery and tray/bracket, intake air box for easier access
1 jack needed dont undo driver mount just start loosen the bolts (up and down bolts not side bolt) itll start lowering undo front mount before loosening driver mount, you only need the jack once the trans mount is on the trans to get the side bolt holes lined up, and to use on driver side to make retightening driver mount easier/faster
imadigitalgod
May 29, 2010 11:32 PM
