Dash/Tail/Running lights off when headlights on
Old May 9, 2016 | 10:38 PM
LSteggyguy's Avatar
Default Dash/Tail/Running lights off when headlights on
1992 Civic DX D15B7 auto sedan
So here's the deal, when the combo switch is set to running lights only, the dash lights are perfect, tail lights are perfect, front marker lights are perfect.
When I flip the actual headlights on is when all the other lights go out immediately.
Brake lights work, turn signals work in both situations
All fuses are good, dimmer wheel thing is working and good.
I can flip the combo switch back and forth and the dash/tail lights will go out when the headlights go on consistently.
Is this an issue with the combo switch/stalk itself?
Old May 10, 2016 | 05:05 AM
HondaTechMan121's Avatar
Default Re: Dash/Tail/Running lights off when headlights on
well u cant see em during the day but at night u can
Old May 10, 2016 | 05:51 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Is this a USDM car or a CDM car?
Old May 10, 2016 | 05:57 AM
Former User's Avatar
^Highly likely
Test the light/combination switch. See FAQs sticky for diagram.
Old May 10, 2016 | 02:34 PM
LSteggyguy's Avatar
Haha, no I tested them in the garage, the lights definitely turn off when the headlights are turned on
straight USDM car, built in the US of A
Old May 10, 2016 | 06:00 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Quite likely still assembled in Canada for USDM market.
That info about USDM tells the wiring guru's like RonJ that there is no daytime running lights circuit in the mess.
Actually simplifies the wiring a fair amount.
Best of luck.
Old May 10, 2016 | 06:12 PM
LSteggyguy's Avatar
Best of luck.
Gotcha, I'd have to assume it is not a CDM model. CDM models have to have the Daytime lights come on when the key is in the on position correct? I believe my 2000 toyota sienna is like that
Old May 10, 2016 | 09:18 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Actually my 95 CDM CX, the lights don't come on until you release the parking brake. So you can idle in stealth up until you release the parking brake.
They also don't shut off once on until you turn the car off.
I've read some models, they go off when you engage the parking brake but my 95 CX doesn't work that way. So to regain stealth you set the brake and shut the car off, then start her back up.
No night stealth driving though, good for safety at least on one end.
Old May 13, 2016 | 12:44 PM
fcm's Avatar
fcm
Old Fart
Your problem is the Combination Light Switch, either a USDM or CDM, or where car was built/assembled, it must be the switch. 94
Old May 13, 2016 | 01:04 PM
StokelesS_g2's Avatar
You could always wire up your HL to your parking lights for nighttime driving.
Or on the safer side, you could install a relay and direct wire it to you battery (inline fuse), then use your parking light wire as a trigger, or buy a switch to activate your HL when you want to.
You can gain alot more brightness too.
Old May 14, 2016 | 01:53 PM
LSteggyguy's Avatar
yup, you were right, I went down to the junkyard and snagged a switch and popped it in and now everything works perfectly.
Old May 14, 2016 | 05:48 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
To be fair to the situation, RonJ stated this by post #4 and directed you to the FAQ for the diagram to be able to verify this without having to spend money on any parts beforehand.
Old May 15, 2016 | 03:37 PM
fcm's Avatar
fcm
Old Fart
94
cgjarvis
10
Aug 7, 2016 12:22 PM
Bexwh773
Lighting
Jan 7, 2016 09:35 AM
Vtec Civic 93
Jan 5, 2011 09:28 AM
rob_dogg55
11
Nov 15, 2006 09:03 PM
ChargedLude97
13
Feb 12, 2004 01:57 PM
