Stock 92 Civic DX - CEL code 9
Hey guys... It's been a while since I've posted... But ever since I dissasembled my distributor to replace the coil my CEL has been on... Well soon after I replaced the coil I had to go back in and replace the coil again (due to the first being faulty), rotor and the cap. Well the CEL is still on. I pulled the code and its #9 for Cylinder position sensor. I don't have a way to check voltage or anything but was wondering if it's a common issue? If so how can I fix it? I've already did the steps to reset the ECU by pulling ECU fuse along with the backup but it still came back.
I read that I needed to remove the backup fuse plus the ECU fuse for 10 minutes. Which I did, then it said to let car run for 10 minutes after putting the fuses back in. The only difference is before when I turned key to II the CEL stayed on and would remain on, now while on II it comes on for a brief moment then cuts off until I turn on the car.
