Need some help / opinions and real testing on the GTX3071R VS GTX3076R VS GTX3576R
Wanting a perfectly matched turbo suiting a F20B engine 1mm oversize pistons with H22a head for circuit/road racing with 420hp/368whp with a built motor & stock gearbox/axles
Also thinking of a 0.82 AR on hot side ?
Also how mush is to mush hp.......with a FWD circuit racer ?
Have 98 octane pump gas in New Zealand
Still learning about reading compressor maps so excuse my ignorance
I have included compressor charts from each which I have plotted :
Violet = 10psi (1.68 pressure ratio) Medium blue = 15psi (2.0 P/R) Purple = 20% peck flow (47.34lb/min x 0.20% = 9.47lbs/min) Green = 20psi (2.36 P/R) Red = min flow 20psi (2.36lb/min) Light green = 8000rpm (42.08lb/min) Dark blue = 9000rpm (47.34lb/min) / 20psi efficiently range
seems not a lot of people aren't using these on their honda's most are garrett or precision, is this a price thing or new release (2013) ?
Also what flange and manifold is going to work the efr7163 uses t25, t4, or v band turbine housing, maybe a custom manifold is needed and internal wastegate or external seems like the efr7163 has a very efficient internal wastegate setup cable of flowing a lot of unwanted pressure vs 38mm or 44mm external ?
They are more expensive; HOWEVER, with the integrated wastegate (that is actually useful) and BOV, you save money purchasing those accessories elsewhere. If you were to buy a Tial Q bov and Tial MVS 38, you're looking at $400-450 right there. Not to mention that since they're integrated, the setup as a whole is just cleaner. There are fewer vac lines and the setup is more compact overall
I have to fix that terminology with viable choices:
T3 open volute
T3 turbine housing
T3 flanged housing
You don't worry about the characteristics of the flanged or volute until it's actually divided at the flange.
Don't use the term "scroll" , unless it's actual description is proper to use.
Remember, a divided housing is not necessarily a "twin scroll". For the GTX3576R, there are options for both divided housing and a true twin scrolled volute. The difference in cost is easily $100 to $200 between the two.
Just one to grow on, but Riceball's GTX3576R is a great way to go for a high VE Cylinder head like the F22C
Reason: Grammar correction
T3 open volute
T3 turbine housing
T3 flanged housing
