New headgasket water in oil (solved)
Old May 8, 2016 | 08:07 AM
sohcpower1's Avatar
Default New headgasket water in oil (solved)
Ok heres the deal my 99 single cam civic had a misfire in cylinder 2 checked compression it was low around 30psi. So i pulled the head found that cylinder exhaust valves were stuck open! Replaced valves put new headgasket new head bolts torqued properly. Car started right up ran relly good but i noticed white smoke coming from the exhaust manifold. Shut the car down seen the oil was milky inside the valve cover. Ran the car again and it looks like the white smoke is coming from the converter aoat like heat sheild is smoking? Not sure but my guess is its just seaping out of the cat somehow. Any ideas?
Old May 8, 2016 | 08:50 AM
Former User's Avatar
Default re: New headgasket water in oil (solved)
Likely a bad head gasket install, unless the block is cracked.
Old May 8, 2016 | 09:02 AM
sohcpower1's Avatar
Was kinda thinking that. I never changed the oil when i took tbe head off and was told coolant could get into oil that way
Old May 8, 2016 | 09:46 AM
Change the oil.
Old May 8, 2016 | 11:08 AM
White_EG1's Avatar
You gotta drain coolant and oil so there's no chance either will mix
parton84
Dec 16, 2013 06:36 AM
JdmJah
16
Feb 19, 2013 06:42 PM
4g4dcruisin
Jan 5, 2013 12:46 AM
em1effekt
18
Jul 6, 2011 04:18 PM
Nextelbuddy
May 3, 2005 06:21 AM
