Dirt Track- Stripped 99 civic suddenly skip then back to normal? (Solved)
We are at the dirt track with our 99 civic sohc car
It suddenly went into a dead skip and 20 seconds later cleared right up
Not sure how to approach an what could cause it
Plug wires look decent
Pretty much
It's all stripped out it does good rAndomly then suddenly misses on ONE cylinder the. Randomly back to normal all night through 3 races
Seems to run best at first stArt up
Went gradually from running on 4 to 3 to 2 cylinders and totally dead altogether
Cluster has been removed , it's a dirt track car interior and dash are gone
its late just got home from the races gonna check fuel pump prime and spark at all 4 plugs tomorrow
got it fixed, tried to test the coil but there are so many million settings on the mulitmeter
I ended up changing the coil and it fired up. I also found the plug wires were junk one was broken at the internal connector that snaps to the plug.
So I assume thats why it would run good then skip when getting bumped on the track it finally lost connection and we raced 3 more races on 3 cylinders and I think it fried the coil discharging with nowhere for the current to go
mshmink
Jan 30, 2013 04:04 PM
lsvtek
Mar 23, 2011 05:34 AM
LastGenEK
Apr 14, 2010 03:59 PM
redm3turbo
Jul 5, 2006 12:05 PM
