94 H22 Tranny Question.
Hey guys, My Lude is Grinding into 3rd gear alot now. Im plannin on switching out the clutch to an ACT 6 puck with the flywheel. the whole deal. But my question is... Are there such things as Heavy Duty Sincros? My local shop that i go to said that those will be great for racing... if so do u guys have an estimate how much it'll be.... and wat company its from? thanx again
never heard of beefier synchro's maybe level10 or Prodrive might have something. I am just gonna cryo my whole tranny, I hear a stock h22 tranny will hold up to 400+ hp at the wheels so i should be perfectly fine since I only get about 1/2 that.
stock lude trannys are known for throwning there "syncros" in the *******. But heres the thing eveything else in the tranny is build for omse abuse. Step used to run a stock lude tranny at the very dawn of the yellow hatch. Actually he ran it till he switched cars. You can call quaife they can set you up with something. And Poor DRive after seeing the so called 285hp na car get wipped i dont belive **** the say r do. Good luck, by the way ACT is crap. I had it in my car and the splines on the disc ***** (<--wore) away after a year. Now i got a good old CM and the car is good to go. be carefull hope all works well
