99 Civic EX - Bad driver side engine motor mount? (pic included)
Old May 3, 2016 | 04:31 PM
TXaggie's Avatar
Default 99 Civic EX - Bad driver side engine motor mount? (pic included)
Hi everyone,
I have a 1999 Civic EX D16Y8 (133,000 miles). I am getting an occasional random vibration from the engine bay when accelerating. The vibration stops as soon as I take my foot off the gas. The vibration generally occurs at lower speeds (between 30-40 mph) and does not occur when I'm on the interstate at higher speeds. It's fine at idle too. I've included a pic of the driver side engine motor mount. It seems like there's not much spacing between the two black pieces of the upper and lower part of the mount. They're almost touching. Is this a sign my engine mount is wearing out or does it look ok? Could this be the cause? Thanks.
Old May 3, 2016 | 04:50 PM
Former User's Avatar
Default re: 99 Civic EX - Bad driver side engine motor mount? (pic included)
I don't see anything concerning with that mount.
Have you inspected the other mounts (trans, rear, and 2 torque mounts)?
Have you inspected the axles?
Old May 3, 2016 | 05:48 PM
civic402lx's Avatar
My 98 lx torque mount were torn. Replace with new one and now I get a little vibration. But I'm sure it's because of the new torque mount(driver)..
I would check that first.
Old May 3, 2016 | 07:32 PM
TXaggie's Avatar
I've looked at the trans and rear mount and I believe they're ok, although it's a little bit difficult to see all of it as the bracket is partially in the way. When you say torque mount what part are you referring to? Or where is it located? I'm not familiar with that part but will check it. Haven't checked the axles either but will look at that too. Thanks guys.
Old May 3, 2016 | 07:36 PM
Torque mounts are on the front left and right sides of the engine:
Old May 4, 2016 | 04:58 PM
slomofo's Avatar
GDD Member
Default Re: 99 Civic EX - Bad driver side engine motor mount? (pic included)
Are any of your axle boots split or leaking?
Old May 4, 2016 | 11:19 PM
eghatch9295's Avatar
Stancetard Hate Monger
if auto, have a helper sit in the car, foot on brake and shift thru gears. look for the engine moving , anything other than a small amount of movement when shifted is too much. if you grab onto it, can you move it at all?
Old May 5, 2016 | 03:47 PM
tamboo's Avatar
10 Year Member
if u r a super cheap@ss like me just fill in you old mounts with window weld:
2 Dow U 428 Auto Glass Windshield Urethane Primerless Adhesive Glue Sealant | eBay
works great for peanuts.
i did buy a new rear mount and filled that in too since everyone says it's a nightmare.
it was, never again in this lifetime plz dear god! 8(
Old Oct 23, 2025 | 10:02 PM
Civvy99ex's Avatar
blow mount 100% destroyed
100% gone
100% gone
Old Oct 24, 2025 | 08:37 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Time to replace that one for sure !!! ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
saemoonyang
11
Nov 3, 2011 12:33 PM
ep2integra
Honda Civic (2001 - 2005)
Aug 6, 2009 08:22 AM
littlered
Jan 23, 2007 11:10 AM
SupaMien
Oct 13, 2006 05:20 AM
Vtecivic99
Sep 20, 2002 05:08 PM
