99 Civic EX - Bad driver side engine motor mount? (pic included) - Honda-Tech - Honda Forum Discussion
Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Model-Specific Technical Forums > Honda Civic / Del Sol (1992 - 2000)
Reload this Page >
Old 05-03-2016, 04:31 PM
Default 99 Civic EX - Bad driver side engine motor mount? (pic included)
Hi everyone,
I have a 1999 Civic EX D16Y8 (133,000 miles). I am getting an occasional random vibration from the engine bay when accelerating. The vibration stops as soon as I take my foot off the gas. The vibration generally occurs at lower speeds (between 30-40 mph) and does not occur when I'm on the interstate at higher speeds. It's fine at idle too. I've included a pic of the driver side engine motor mount. It seems like there's not much spacing between the two black pieces of the upper and lower part of the mount. They're almost touching. Is this a sign my engine mount is wearing out or does it look ok? Could this be the cause? Thanks.
TXaggie is offline
Old 05-03-2016, 04:50 PM
Default re: 99 Civic EX - Bad driver side engine motor mount? (pic included)
I don't see anything concerning with that mount.
Have you inspected the other mounts (trans, rear, and 2 torque mounts)?
Have you inspected the axles?
Former User is offline
Old 05-03-2016, 05:48 PM
civic402lx's Avatar
My 98 lx torque mount were torn. Replace with new one and now I get a little vibration. But I'm sure it's because of the new torque mount(driver)..
I would check that first.
civic402lx is offline
Old 05-03-2016, 07:32 PM
I've looked at the trans and rear mount and I believe they're ok, although it's a little bit difficult to see all of it as the bracket is partially in the way. When you say torque mount what part are you referring to? Or where is it located? I'm not familiar with that part but will check it. Haven't checked the axles either but will look at that too. Thanks guys.
TXaggie is offline
Old 05-03-2016, 07:36 PM
Torque mounts are on the front left and right sides of the engine:
Old 05-04-2016, 04:58 PM
GDD Member
slomofo's Avatar
Default Re: 99 Civic EX - Bad driver side engine motor mount? (pic included)
Are any of your axle boots split or leaking?
slomofo is offline
Old 05-04-2016, 11:19 PM
Stancetard Hate Monger
eghatch9295's Avatar
if auto, have a helper sit in the car, foot on brake and shift thru gears. look for the engine moving , anything other than a small amount of movement when shifted is too much. if you grab onto it, can you move it at all?
eghatch9295 is offline
Old 05-05-2016, 03:47 PM
tamboo's Avatar
if u r a super [email protected] like me just fill in you old mounts with window weld:
2 Dow U 428 Auto Glass Windshield Urethane Primerless Adhesive Glue Sealant | eBay
works great for peanuts.
i did buy a new rear mount and filled that in too since everyone says it's a nightmare.
it was, never again in this lifetime plz dear god! 8(
tamboo is offline
stackz
11-08-2006 10:33 AM
ProjectDarkBlack
03-17-2005 04:54 PM
BlVlW313
10-17-2003 04:08 PM
Quick Reply: 99 Civic EX - Bad driver side engine motor mount? (pic included)
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
Question Title:
Description:
