2000 ek will start but won't stay on.
Old May 2, 2016 | 08:11 PM
mateen123's Avatar
Default 2000 ek will start but won't stay on.
hello guys, i have a 2000 ek with b16 swap. I recently pulled the motor out rebuilt it and put it back in. Started up amazing after the rebuilt. Made sure if everything was ok, no codes. So later I took it to a shop to get my exhaust put on and on the way there I was having some fun lol. When I got close to the lights, put my clutch in and realized my car turned off. I had to hit the gas a couple times for it to start back up and even if it does starts shuts of right away. Until I keep on giving it gas runs fine after while I driving. It also jerks at low gear and high rpm. Please and tank you
Old May 2, 2016 | 08:22 PM
mk378's Avatar
Default Re: 2000 ek will start but won't stay on.
So basically you are saying it will run if you keep pressing the gas, but it won't idle. The first thing to check there is your IACV. Make sure all the engine harness plugs are plugged into the proper things by checking the wire colors. The 2P plugs are all the same and you can mis-plug them.
Old May 2, 2016 | 09:04 PM
Former User's Avatar
Post the CEL codes.
B16a2? What ECU?
Old May 3, 2016 | 09:45 AM
slomofo's Avatar
GDD Member
Is it an EK or an EJ?
Old May 3, 2016 | 10:46 AM
mateen123's Avatar
its a 2000 civic ek no codes besides the 2nd o2 sensor. Also it the car started this morning and I highly think its the spark plugs and the wires. I am gonna go today to grab some new plugs and hope for the best.
Old May 3, 2016 | 01:37 PM
slomofo's Avatar
GDD Member
So it says EK on the VIN number?
Old May 3, 2016 | 01:42 PM
Where were EKs marketed? Only Asia? Or also Europe?
Edit: Found this post:
https://honda-tech.com/honda-civic-d...6/#post7467465
Old May 4, 2016 | 12:45 PM
slomofo's Avatar
GDD Member
IDK, you're the moderator here, you tell me.
Old May 4, 2016 | 12:50 PM
I'm darn sure you know. Why? Because slomo.
Old May 4, 2016 | 12:51 PM
slomofo's Avatar
GDD Member
Reset my post count to zero.... I'll disappear.
Old May 4, 2016 | 12:52 PM
Scout's honor?
Old May 4, 2016 | 03:16 PM
slomofo's Avatar
GDD Member
Yes sir.
So up until last week I would delete an old post every single day and it kept going up even though I stopped posting. I just gave up and said fuggit, I'll shoot for 100.
Old May 4, 2016 | 03:23 PM
Yes sir.
Sure, I'll contact IB Jose.
By the way, I'm fine with you posting in tech forums as you do make helpful contributions. Just try to leave the GDD posts in GDD. This is likely moot, however, if you wish to maintain a 0 post count. Should I ask IB Jose if there's a way to maintain 0 posts even if you post in tech?
Old May 4, 2016 | 03:58 PM
BoostedPunisher's Avatar
I'm sure it's your iacv. But a code throwing for your downstream O2 sensor isn't no codes! The sensor tells the ECU what's going on after the cat. With the car running fine after its warm probably is both sensor and valve. You can use a multi meter to test resistance in valve. Just replace the O2 sensor
Old May 4, 2016 | 04:50 PM
slomofo's Avatar
GDD Member
First post edited by RonJ.
Damn bro, you're off to a rocky start.
OP, are your thermostat or transmission ground wires loose at all?
Old May 4, 2016 | 08:20 PM
mateen123's Avatar
sorry guys been busy wit work. Ok so checked engine light and i did get the code p1508 for IACV malfunction. Also checked my timing and it jumped three tooth.
Old May 4, 2016 | 11:17 PM
eghatch9295's Avatar
Stancetard Hate Monger
ah. the mistake was assuming the work was done correctly. wot+improper tension= you lose.
HaNgTiZZy
Northern California (Sales)
Dec 13, 2007 11:48 AM
