2000 ek will start but won't stay on.
hello guys, i have a 2000 ek with b16 swap. I recently pulled the motor out rebuilt it and put it back in. Started up amazing after the rebuilt. Made sure if everything was ok, no codes. So later I took it to a shop to get my exhaust put on and on the way there I was having some fun lol. When I got close to the lights, put my clutch in and realized my car turned off. I had to hit the gas a couple times for it to start back up and even if it does starts shuts of right away. Until I keep on giving it gas runs fine after while I driving. It also jerks at low gear and high rpm. Please and tank you
Re: 2000 ek will start but won't stay on.
So basically you are saying it will run if you keep pressing the gas, but it won't idle. The first thing to check there is your IACV. Make sure all the engine harness plugs are plugged into the proper things by checking the wire colors. The 2P plugs are all the same and you can mis-plug them.
its a 2000 civic ek no codes besides the 2nd o2 sensor. Also it the car started this morning and I highly think its the spark plugs and the wires. I am gonna go today to grab some new plugs and hope for the best.
Where were EKs marketed? Only Asia? Or also Europe?
Edit: Found this post:
https://honda-tech.com/honda-civic-d...6/#post7467465
By the way, I'm fine with you posting in tech forums as you do make helpful contributions. Just try to leave the GDD posts in GDD. This is likely moot, however, if you wish to maintain a 0 post count. Should I ask IB Jose if there's a way to maintain 0 posts even if you post in tech?
I'm sure it's your iacv. But a code throwing for your downstream O2 sensor isn't no codes! The sensor tells the ECU what's going on after the cat. With the car running fine after its warm probably is both sensor and valve. You can use a multi meter to test resistance in valve. Just replace the O2 sensor
sorry guys been busy wit work. Ok so checked engine light and i did get the code p1508 for IACV malfunction. Also checked my timing and it jumped three tooth.
