Refresh of 94 Civic Si w/ ABS after accident
My Civic got pasted by a Jeep last November, and now I should be able to spend a little time to get her back on the road.
I got my Si back in '97 and love it. The clutch started slipping @ ~140k miles back in 2002, and I had been reading up on the B18C1 swap, so I went for it.
Now she has ~266k on her, and I can tell the B18 is feeling tired, and the exhaust smells a little bit.
Funds are limited - I set the goal of completing the re-fresh with only the funds from the accident, but I think I can do it!
In my mind, the re-fresh has 3 components:
1) Basic engine rebuild. I intend to pull the head and send it out to the machine shop for surfacing and valve job. I will also tap out the rods and throw new pistons and rings on them.
2) Replace front end sheet metal - hood, both fenders, bumper skin. I think I will need to play with the radiator cross-member as well to get hood latch in proper location, hard to tell with mangled hood.
3) Replace passenger side knuckle as alignment shop can no longer get camber set on pass side after the accident.
Here is the fun picture of what happened:
For the basic engine rebuild, I was going to purchase OEM pistons, rings, timing belt, water pump and tensioner.
First (of many) question, it looks like I need to order many gaskets separately for this rebuild. Does anyone have a part number list of all the Honda gaskets required?
I think I need to order the following:
-Head gasket
-Cylinder head ("head cover") kit
-VTEC solenoid gaskets
-Intake manifold
-Exhaust manifold
-Water pump gasket (may be included with pump?)
-Oil pan gasket
What am I missing? Do I need distributor gasket(s)?
Thank you!
-Head gasket
-Intake manifold
-Exhaust manifold
-Oil pan gasket
Thank you!
Doesn't look like too many are interested in this topic, but I will go ahead and post up as I go through the project if it can help anyone else.
I plan on running a compression test before I tear the engine down, as it seems low on power these days.
My plates expire this month, so I had to take it in for an emissions test, and she passed with flying colors:
HC - 0.2569/1.2000
CO - 3.2713/15.0000
CO2 - 272.1080
NOx - 0.5636/3.0000
HC - 0.2569/1.2000
CO - 3.2713/15.0000
CO2 - 272.1080
NOx - 0.5636/3.0000
-Head gasket
-Intake manifold
-Exhaust manifold
-Oil pan gasket
Thank you!
-Head gasket
-Intake manifold
-Exhaust manifold
-Oil pan gasket
Thank you!
Choose a GSR year between 94-01 and start ordering parts.
eH.
If you want OEM, I recommend Acura Parts | OEM Acura Parts | Factory Acura Parts
eH.
eH.
Creeping ever so slowly towards this project.
It looks like to remove crank pulley, the driver side wheel/tire needs to come off, so I cannot use ramps. Is the best place to position jack stands where the lower control arms insert into the bushings?
Also, when I got the swap done, the shop that did this said they had to replace the distributor, and all I remember about the conversation is that they used a dizzy with a smaller cap, as it was more readily available, and less expensive.
Any reason to seek out the GSR dizzy my engine used to have?
What is the best place to get a distributor? Is there a reputable rebuilder in the community?
Thanks!
Thanks!
Is your car running OBDII or OBDI?
That will make a difference on which distributor you will need. I was in a hurry to get my car running when I got mine (after swapping) and bought a brand new one from the parts store and they cost a pretty penny, so just changing the cap and rotor yourself would probably be a better option.
By the way, how can you tell if your car is "tired". Have you had the car dyno'ed or had a compression and leakdown test? Just to be sure you spend your time and hard earned money on useful stuff...
Good luck on the car refresh.
And very good point on compression test. I need to do this.
I can change the cap and rotor in my existing distributor, but I am curious, if my current dizzy is say from a LX, would there be any performance benefit to getting a GSR dizzy?
-Head gasket
-Intake manifold
-Exhaust manifold
-Oil pan gasket
Thank you!
-Head gasket
-Intake manifold
-Exhaust manifold
-Oil pan gasket
Thank you!
Re-ring means rebuild of the bottom end since pistons have to be pulled out.
And in that case, you need to blue print the motor so you know the cylinders are within service limits for out of round and taper. Let alone crank run out etc.
If they are beyond service limits then it means new pistons and rings, a bore and hone and all new bearings as well as all new seals in the block, and might as well do a new oil pump since it's torn down that far.
Lets say you are in service limit and the oil pump is in service limit also, bare minimum is all new seals (oil pickup tube seal, oil pump o-ring seal, front main, rear main, oil pan), then all new bearings, a light hone and new rings. And since it's all apart, new water pump and gasket and new timing belt. And since you are doing all of that, might as well do a new o-ring and grommet on the oil breather box on the back of the block as well as a new PCV tube that goes to the breather box, those are usually hard and brittle by now.
I'm sure I'm missing something in that list but it's a decent start.
Just did a quick read through your post.
May have missed replies already saying these things but here they are again anyway.
Gasket kit... You can tend to find these kits on ebay, they are not OEM but it is typically how to get the majority of gaskets you need in one shot and cheaper. Sometimes cheaper quality too though.
Pulley and supporting the car... The jack stand goes to the car's jacking point which is the metal plate right behind the front wheel well. That is one of 7 jacking points on the car. And actually the tow hook on the rear of the car I am not sure is considered a jacking point but I have used it once in awhile (very rarely) so there may only be 6 official jacking points, 2 up front and 2 on each side.
In reality you should have two factory service manuals you are looking through. One is the 92-95 civic manual or the specific 94 civic si helms manual if you go and buy it from helmsinc.com then the second manual would be for the 94-01 acura integra gsr someone else mentioned. That one is for the motor.
In both manuals you will be able to get all the information you need for specs, jacking points, etc etc.
It won't help you with the body work though, that is the body manual from helmsinc.com for the 94 civic. It's one manual I've not ogled yet but just may get someday for my cars.
Best of luck.
Best of luck.
Best of luck.
Best of luck.
Are there any links to Helms manuals here in the forum?
Thank you,
I had one distributor fail back in the day, still have it. Does anyone rebuild these?
I also need to figure out what hoses to buy for replacement of old hoses.
My car has radiator for a Del Sol VTEC in it, so it fits the Civic body, but has the larger openings. Last time I replaced the radiator hoses, the Del Sol VTEC hoses were not the correct application for top or bottom.
Am I correct that all the hoses on the block should be good ordering for '96 GSR?
Heater hoses - order for a '94-'97 Del Sol VTEC?
Thanks for your help!
Thank you TomCat, can you elaborate on the jacking points? I have used the rear tow hook, and the area on the front radiator crossmember. I am with you on the 2 jacking points per side, but what are the 2 up front?
Thank you,
Thank you,
Here is a pic of mine on the passenger side from a 95 civic hatch:
And yes, I believe you have the B16A2 motor so need B-series radiator hoses as the B-series is a touch larger.
Thanks![/QUOTE]
You have two plates on the front, one to the left and one to the right. Two metal plates with a hole in it sticking down. I use that to jack up the front all the time to put my jack stand on the side.
Attachment 418819
Attachment 418819
I am running a B18C1 in my '94 Si. I know the last time I went to replace radiator hoses the Del Sol VTEC rad hoses did not work for both top and bottom. I think I took notes on this, so I will check.
Do you know what heater hoses work for B18/EG? I want to replace while I have intake off and head out...
Not really, all the components inside the distributor at the same. Actually all the electronics inside are the same between B and D series, even OBD1 and OBD2 are the same internally, the only thing that changed was the connector(s).
If there's nothing actually wrong with I'd leave it alone. The aftermarket units aren't much good. If you really need one you can buy the housing which comes with the bearing and the CKP/CYP/TDC sensors from Honda.
Thanks!
Thanks!
Also, some questions about shifters... With the B swap, my shifter moved forward a noticeable amount. I have always wanted to shorten it up a touch to bring it back to stock placement for the Si. Has anyone done so? Favorite place to take out the extra length?
I think the angle the shifter is at with the extra length causes rattles in 3rd and 5th. No rattles in 4th.
I looked up some threads on this and it sounds like folks prefer I start a new thread. Other forums I frequent often chastise the newb for starting a new thread when they should have searched, the thinking being that the information had already been put out. I will accommodate the New Thread preference here though.
The reason for new threads instead of bumping really old threads is that every car is different. What applied in the old thread may not be your same situation, especially as easy as it is to swap and modify Honda's.
You simply reference the threads/posts you found and then ask in your thread clarifying questions as it applies to your vehicle.
Hope that makes sense and is helpful to you.
