Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2008 Si : have compression, spark, fuel & air NO START video
Old Apr 28, 2016 | 01:11 PM
rexload's Avatar
Default 2008 Si : have compression, spark, fuel & air NO START video
2008 Si, stock motor
Compression 160-165 on all cylinders
Getting spark on all plugs
Getting fuel
Air filter good, no restrictions
Known good CKP
Fuel tank drained and refilled with fresh gasoline
Battery charged
Cranks slow and NO START
Connected to another running vehicle with battery jumper cables but still cranks slow
VIDEO of me doing a few short cranks with plug #1 in the video
Old Apr 29, 2016 | 07:41 AM
foumer's Avatar
W95 gives me a hard-on
Default Re: 2008 Si : have compression, spark, fuel & air NO START video
Whats the history on this car. Did this just happened? Any weird noises or problems before hand?
Old Apr 29, 2016 | 08:31 AM
rexload's Avatar
Thanks for the response
Unfortunately no history
Got the car in AS IS unknown condition
Towed home
Looked at the plugs and they were soaked in gasoline meaning somebody was cranking it quite a lot
Did dry compression test
Installed new plugs
Installed known good crank and cam sensors
Drained gas tank and replaced fuel strainer
Filled tank with fresh gas
Cleaned air intake box and installed new air filter
The only other thing I can tell is that the car was driven through sand/offroad as there was a sand on top of gas tank and in the air intake box
Old Apr 29, 2016 | 09:06 AM
rexload's Avatar
Some other ideas I've had:
Should I check if the timing chain jumped?
Should I pull the starter and test the starter?
Old Apr 29, 2016 | 10:49 AM
fcm's Avatar
fcm
Old Fart
Check/redo the main grounds, batt. to chassis and chassis to engine, DO NOT just eyeball them, disconnect/clean/reconnect, [a tight ground lead does not necessarily mean a good ground.
Also check/clean the batt. pos. cable at the batt. and at the starter motor. 94
Old Apr 29, 2016 | 03:38 PM
rexload's Avatar
Checked positive battery cable and did voltage test. Getting 12 volts on the cable at the starter. The cable is clean as can be.
Ground from battery to engine is solid - I use a second set of jumper cables as a ground from battery to engine block.
Also pulled the starter off the car and hooked it up to a battery, seems to be working okay, spins fast. Not sure if this rules out the starter completely.
Old Apr 30, 2016 | 07:13 AM
foumer's Avatar
Just to get it out the way and rule it out check the timing chain.
Old May 3, 2016 | 01:57 PM
rexload's Avatar
Took off valve cover and spark plug closest to crank pulley (this is number #1, correct?)
Inserted long straw into cyl#1 and rotated crankshaft to find TDC
This is what I discovered, one photo is TDC on compression stroke, the other photo is TDC on exhaust stroke
<a href="http://s248.photobucket.com/user/rexload/media/IMG_20160503_170825984_HDR.jpg.html" target="_blank"><img src="http://i248.photobucket.com/albums/gg195/rexload/IMG_20160503_170825984_HDR.jpg" border="0" alt=" photo IMG_20160503_170825984_HDR.jpg"/></a>
<a href="http://s248.photobucket.com/user/rexload/media/IMG_20160503_170716678.jpg.html" target="_blank"><img src="http://i248.photobucket.com/albums/gg195/rexload/IMG_20160503_170716678.jpg" border="0" alt=" photo IMG_20160503_170716678.jpg"/></a>
At this point, should I try to reset the chain/install new chain tensioner, and then do a leak down test?
Or is it safe to assume that the motor is toast?
Old May 4, 2016 | 04:02 AM
foumer's Avatar
Timing marks should align like this at TDC.. The only thing that I dont know if the crankshaft pulley has timing marks outside the timing cover. Also here is a link to an online manual where I got these illustrations from http://civic.hondafitjazz.com/manual2.html
Old May 4, 2016 | 04:25 AM
foumer's Avatar
Just found this illustration for an RSX K20. There should be an outside timing mark on the pulley
Old May 4, 2016 | 04:41 AM
rexload's Avatar
Thank you! Those illustrations are very helpful.
Yep, nothing lines up. It's not even close.
Old May 4, 2016 | 07:34 AM
foumer's Avatar
If it jumped timing then hopefully the pistons didnt hit the valves. At this point try to get the engine in timing and do a leak down test afterwards.
Old May 4, 2016 | 09:26 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^ and cross your fingers. 94
benh
Honda CR-V & Element
Aug 4, 2018 05:25 AM
kaiba
Jan 14, 2011 02:16 PM
Jos3ph
Nov 13, 2008 04:35 PM
n3h3bkau
Nov 2, 2007 10:51 AM
kasso
Mar 23, 2006 01:38 PM
