My F20b w/F23A1 & k series internals NJ
Old Apr 26, 2016 | 04:13 PM
HondaMike92's Avatar
Default My F20b w/F23A1 & k series internals NJ
so I decided to do a build I haven't done before I've built H22 I've built f23 but never an f20b of course the f23 are cheaper to build being that you do not have to sleeve them unlike the H22 the f20b also does not have to be sleeved, it does not have the fiber reinforced sleeves like the H22 so that is what I decided to go with plus I have one laying in my garage LOL so with the parts I have left over in my garage I used the f20b block, F23a1 crank, H beam rods for the F23a1 and K20 wiseco forged pistons 9-5-1 compression. I had the block bored out to fit the 1mm bigger pistons and I'm going to be boosting this setup on 12 lbs. I'm running a JDM H22a built head with stage 2 BC turbo cams BC retainers and duel valves springs and a mild port and polish arp head bolts and high flow oil pump. I'm really excited to see how this build turns out and the kinda power it's gonna make.
any suggestions or comments I'd be happy to hear ty
Old Apr 28, 2016 | 11:01 AM
ESP.net's Avatar
Default Re: My F20b w/F23A1 & k series internals NJ
You do the math on it? What are the specs of the pistoms dome cc and compression height?
Old Apr 28, 2016 | 11:08 AM
ESP.net's Avatar
Should be okay... 0 deck, overal compression comes out to 10-1 with stock headgasket.... -3.4 dome cc and 30mm compression height.
Old Apr 28, 2016 | 11:52 AM
2kdrift's Avatar
Sounds like a cool build.
12 PSI means nothing tho, we have no Idea what your power goal is. 12 PSI could be 200 HP on a particular turbo and 500 on another
Old Apr 28, 2016 | 12:08 PM
ESP.net's Avatar
12 psi on 97mm would probably get you over 375 whp if turbo is bigger thatn 60mm
I am not a fan of ANYONES turbo cams... to be honest... I have seen them hurt overall hp and more importantly torque on dyno sheets I have seen. Use valve springs etc but use stock cams!!!! Most under 600hp use stock cams!!! the stock cam will provide more torque down low and midrange... what you want....
Old Apr 28, 2016 | 02:12 PM
TheShodan's Avatar
Moderator
I agree with the above. Stay stock cam or no larger than a Tuner 1 (if that's available in an H22, I don't remember, honestly) with an H22 head for this type of desired use. I may have mentioned this before.
Old Apr 28, 2016 | 03:05 PM
bcintron95's Avatar
Interesting. What turbo are you going with?
New port richey represent! Lol
Old May 2, 2016 | 06:11 PM
T3 T4 50 trim
Old May 2, 2016 | 06:41 PM
The head I have came fully built so the cams were in it. Should I sell them and put in my JDM H22a cams or I have type s cams from a f20b I got in trade?
Old May 2, 2016 | 06:50 PM
ESP.net's Avatar
Yes Stock Cams JDM H22 or Type S F20B MT cams however EuroR/TypeS cams must have the matching Valve Springs... or you will have rocker issues etc. So stock usdm or jdm h22 cams best.
Yes on a smaller T3/T4 50 trim... bigger cams would only be pointless but you would actually lose hp and torque.
Blacksi76
Mar 7, 2011 10:02 AM
97_Built
Dec 10, 2009 11:13 PM
rollercosta123
Aug 30, 2006 07:28 PM
MadCityLude
Jul 15, 2006 12:07 PM
