FPR vs AFC??
Old Nov 7, 2002 | 09:17 AM
spun Vtec's Avatar
Default FPR vs AFC??
whats the diff bettween an FPR and an AFC??obv the fpr has to do with vacume and presure just how does it work and does an afc work on volts? i have no idea thanks alot ! what are the pro's / cons?
Old Nov 7, 2002 | 09:27 AM
zCivic's Avatar
Default Re: FPR vs AFC?? (4gsicivichatch)
FPR=Fuel pressure Regulator. It adjust the fuel pressure in the fuel rail
AFC=Air Fuel Controller. It adjust the injector fuel settings. Adjusting the air/fuel mixtures.
If you need more fuel pressure you need a larger fuel pump or a adjustable FPR.
The AFC will only adjust how the fuel/air mixtures. There totally 2 different things.
The adj FPR will allow to to adjust the pressure the fuel rail to injectors is seeing but wouldn't adj your fuel/air mixtures AFC will adj your fuel/air mixtures but not raise fuel pressure.
FPR works with Vacumn it has a Diafram which will only allow a set amount of fuel to store in the fuel rail if anything over that set amount will return to the fuel tank.
the AFC is electronic usually works off the map sensor.
onefstek
Nov 18, 2005 01:55 PM
Bantam
Mar 7, 2003 08:58 AM
db2b17a-R
Nov 21, 2002 05:24 PM
LshatchTurbo
Oct 20, 2001 10:34 AM
