exhaust manifold paints
Old Apr 22, 2016 | 02:30 PM
RACEPAK's Avatar
Default exhaust manifold paints
hello everyone
i'v been using vht and por15 manifold paints, and i didn't like the vht much, it had particles in the paint and change color when heats up, but the por 15 is awesome, but very expansive.
any of you guys can recommend a cheaper alternative?
thanks i use paint gun, not aerosols
vht:
por15:
Old Apr 24, 2016 | 04:12 AM
Sikocivic's Avatar
Default Re: exhaust manifold paints
I went to a local Fireplace and Wood Stove store near me and bought paint in a rattle can. Holds up great even on the turbo. It also comes in a few different colors.
This is the stuff I bought,
High Heat Fireplace and Stove Paint Primer Metallic Red
Old May 6, 2016 | 07:25 AM
LightningTeg's Avatar
Community Builder
how many coats of that POR15? I had my buddy do my last manifold and it didnt take long at all for it to flake off.
Old Jun 16, 2016 | 06:45 AM
CivicBlacksheep's Avatar
10 Year Member
I also used high temp grill paint. Black works real good for me and has held up for the last 3 months of usage everyday.
Old Jul 28, 2016 | 08:02 AM
Hondasfordays's Avatar
I've never used the POR15 for exhaust, just undercoating but I've had really good luck with the VHT in the past. It will change colors slightly after a heat cycle or two as the paint is curing. I've found it really works the best if you pre-cook the parts in an oven first before putting on the vehicle. When it's installed follow the break in procedure on the can. Mine has held up for about 5 years and looks pretty good considering (I always use the black).
Old Oct 23, 2016 | 09:25 AM
PhillipM's Avatar
I've never found any paint that will last short of proper ceramic coatings.
u n v kenny
Jul 3, 2007 11:10 AM
oxSLEEPERxo
Oct 21, 2004 11:16 AM
booscivic
Dec 17, 2003 10:10 AM
inspyral
Apr 27, 2003 01:11 AM
zRd#1
Nov 29, 2002 03:10 PM
