T3 Turbo Flange Porting???
Old Apr 22, 2016 | 01:29 PM
bluenc-87's Avatar
Default T3 Turbo Flange Porting???
Hi,
I have a Garrett T3 50 trim turbo and a SPA rep cast top mount manifold from ebay. The turbine port is too small. From the pic below, the Turbine width is 1/8" smaller and the Length is 1/4" smaller. I dont know if that's usually normal having to port the the turbine housing? I'm not sure if I really want to port the Turbine larger as it may too big of a enlargement or cause cracking?
Top= Turbine
Bottom= Manifold
Turbine
Old Apr 22, 2016 | 01:35 PM
DA9_LEO's Avatar
Default Re: T3 Turbo Flange Porting???
That's A lot of material, from past experience I would open it up at and angle and try to keep it as smooth as possible, seems like a lot of material in the last picture, best of luck ive seen it done before with 0 issues
Old Apr 22, 2016 | 04:08 PM
bluenc-87's Avatar
Feel like it's too excessive. I'm assuming sometimes ppl do have to port it out some, but not this much. First time going boost so I'm unsure.
Old Apr 22, 2016 | 04:33 PM
Turbo-LS's Avatar
Leave it alone. It'll flow 1000hp like that. You could taper it but don't remove a ton of material
Old Apr 22, 2016 | 05:28 PM
TheShodan's Avatar
Moderator
Definitely ok as it sits now. the only porting I ever did was at the inner volute back in 2010. that took a LOT of time. I don't plan on ever doing it again.
Before
After
carlosd68
Jul 28, 2012 09:29 AM
Everyones Hero
Oct 25, 2006 07:28 AM
kenbdSi
Sep 12, 2006 04:50 PM
ITS_Dunn
Feb 1, 2006 07:29 PM
servion
Oct 1, 2002 11:56 AM
