installed new antenna mast today. what is the clear tubing hooked to antenna motor??
i see the clear tubing hooked to antenna motor. where does that go. and what does it do. i suspect that the water that leaks into the antenna slot drains out the tubing? i see no rubber around the antenna end. just wondering. thanks.
